Home » Eclipse Projects » Nebula » GalleryTreeViewer: GalleryItem description with ListItemRenderer
GalleryTreeViewer: GalleryItem description with ListItemRenderer [message #60539] Wed, 19 November 2008 11:21 Go to next message
I was wondering if there's a way to have the ListItemRenderer show the
GalleryItem's description when using the GalleryTreeViewer?
My guess is that the JFace API basically means this is not possible and
the viewer would need to be replaced with a raw Gallery widget, right?
Many thanks,
Justin
Re: GalleryTreeViewer: GalleryItem description with ListItemRenderer [message #60852 is a reply to message #60539] Fri, 21 November 2008 09:29 Go to previous messageGo to next message
This is not currently possible, but we could use the ITableLabelProvider
and use columns to select which String we ask.
Column 0 : Label
Column 1 : Description 1
Column 2 : Description 2
A few changes are required in the viewer.
Can you open a bug for this ?
Nicolas
Justin a écrit :
> Many thanks,
> Justin
Re: GalleryTreeViewer: GalleryItem description with ListItemRenderer [message #60899 is a reply to message #60852] Wed, 26 November 2008 03:26 Go to previous message
Hi Nicolas,
That's a cool idea. Enhancement request added!
https://bugs.eclipse.org/bugs/show_bug.cgi?id=256552
Justin
Nicolas Richeton wrote:
> Column 0 : Label
> Nicolas
> Justin a écrit :
>> Many thanks,
>> Justin
Re: GalleryTreeViewer: GalleryItem description with ListItemRenderer [message #592788 is a reply to message #60539] Fri, 21 November 2008 09:29 Go to previous message
Column 0 : Label
Nicolas
Justin a écrit :
> Many thanks,
> Justin
Re: GalleryTreeViewer: GalleryItem description with ListItemRenderer [message #592824 is a reply to message #60852] Wed, 26 November 2008 03:26 Go to previous message
Hi Nicolas,
Justin
> Column 0 : Label
> Nicolas
> Justin a écrit :
>> Many thanks,
>> Justin
Previous Topic:Gallery: no SelectionEvent when selection becomes empty
Next Topic:[GalleryTreeViewer] ListItemRenderer not honoring IColorProvider
Current Time: Tue Jul 08 09:56:03 EDT 2025
Powered by FUDForum. Page generated in 0.30098 seconds
