Home » Eclipse Projects » Nebula » StackOverflowError by traversing a table
StackOverflowError by traversing a table [message #60443] Mon, 17 November 2008 06:05 Go to next message
I have a table with readonly columns at the first and last position of the
table and editable columns between them (as shown in the snippet).
The table has more rows than the display can show.
If I double click an editable column to activate the edit mode and press
TAB the cursor goes to the next column as expected. If I press TAB at the
end of the screen I would expect that the cursor jumps to the next (not
visible) row and makes the row visible. But the program stops with a
java.lang.StackOverflowError.
Without readonly columns the traversing works as expected.
Any reply is highly appreciated.
Thanks in advance.
Tino
import org.eclipse.jface.viewers.CellEditor;
import org.eclipse.jface.viewers.ColumnLabelProvider;
import org.eclipse.jface.viewers.ColumnViewerEditor;
import org.eclipse.jface.viewers.ColumnViewerEditorActivationEvent;
import org.eclipse.jface.viewers.ColumnViewerEditorActivationStrate gy;
import org.eclipse.jface.viewers.EditingSupport;
import org.eclipse.jface.viewers.IStructuredContentProvider;
import org.eclipse.jface.viewers.TextCellEditor;
import org.eclipse.jface.viewers.Viewer;
import org.eclipse.nebula.jface.gridviewer.GridTableViewer;
import org.eclipse.nebula.jface.gridviewer.GridViewerColumn;
import org.eclipse.nebula.jface.gridviewer.GridViewerEditor;
import org.eclipse.swt.SWT;
import org.eclipse.swt.graphics.Color;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.widgets.Shell;
public class Snippet {
private class MyContentProvider implements IStructuredContentProvider {
public Object[] getElements(Object inputElement) {
return (MyModel[]) inputElement;
public void dispose() {
public void inputChanged(Viewer viewer, Object oldInput, Object
newInput) {
public class MyModel {
public int counter;
public MyModel(int counter) {
this.counter = counter;
public String toString() {
return "Item " + this.counter;
private class ElementEditingSupport extends EditingSupport {
private TextCellEditor cellEditor;
public ElementEditingSupport(GridTableViewer viewer) {
super(viewer);
cellEditor = new TextCellEditor(viewer.getGrid());
protected boolean canEdit(Object element) {
return true;
protected CellEditor getCellEditor(Object element) {
return cellEditor;
protected Object getValue(Object element) {
((GridTableViewer)getViewer()).getGrid().showSelection();
return String.valueOf(((MyModel) element).counter);
protected void setValue(Object element, Object value) {
((MyModel) element).counter = Integer.parseInt(value.toString());
getViewer().update(element, null);
public Snippet(Shell shell) {
final GridTableViewer v = new GridTableViewer(shell, SWT.BORDER |
SWT.V_SCROLL | SWT.H_SCROLL);
v.setLabelProvider(new ColumnLabelProvider());
v.setContentProvider(new MyContentProvider());
v.getGrid().setCellSelectionEnabled(true);
GridViewerColumn column = new GridViewerColumn(v, SWT.NONE);
column.getColumn().setWidth(100);
column.getColumn().setText("Readonly 1");
column.setLabelProvider(new ColumnLabelProvider() {
public String getText(Object element) {
return ((MyModel) element).toString();
public Color getBackground(Object element) {
return Display.getDefault().getSystemColor(SWT.COLOR_GRAY);
// Writable columns
for (int i = 0; i < 3; i++) {
column.getColumn().setText("Editable" + i);
column.setEditingSupport(new ElementEditingSupport(v));
//2nd Readonly column
column.getColumn().setText("Readonly 2");
ColumnViewerEditorActivationStrategy actSupport = new
ColumnViewerEditorActivationStrategy(v) {
protected boolean isEditorActivationEvent(
ColumnViewerEditorActivationEvent event) {
return event.eventType == ColumnViewerEditorActivationEvent.TRAVERSAL
|| event.eventType ==
ColumnViewerEditorActivationEvent.MOUSE_DOUBLE_CLICK_SELECTI ON
|| (event.eventType == ColumnViewerEditorActivationEvent.KEY_PRESSED
&& event.keyCode == SWT.CR);
GridViewerEditor.create(v, actSupport,
ColumnViewerEditor.TABBING_HORIZONTAL
| ColumnViewerEditor.TABBING_MOVE_TO_ROW_NEIGHBOR
| ColumnViewerEditor.TABBING_VERTICAL |
ColumnViewerEditor.KEYBOARD_ACTIVATION);
MyModel[] model = createModel();
v.setInput(model);
v.getGrid().setLinesVisible(true);
v.getGrid().setHeaderVisible(true);
private MyModel[] createModel() {
MyModel[] elements = new MyModel[10000];
for (int i = 0; i < 10000; i++) {
elements[i] = new MyModel(i);
return elements;
* @param args
Display display = new Display();
Shell shell = new Shell(display);
shell.setLayout(new FillLayout());
new Snippet(shell);
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep();
display.dispose();
Re: StackOverflowError by traversing a table [message #60465 is a reply to message #60443] Mon, 17 November 2008 08:38 Go to previous messageGo to next message
Which version of JFace and GridViewer are you using? I think we had a
bug in JFace 3.4.0 we fixed in 3.4.1 but I could also be that I fixed
the bug in the header_footer branch of Grid where we are combining the
grid and viewer code in one code base.
Could you by chance give the header_footer branch a try else please file
a bugzilla and CC me on it then I'll fix the problem.
Tom
Tino schrieb:
> Hello,
> the table and editable columns between them (as shown in the snippet).
> the end of the screen I would expect that the cursor jumps to the next
> (not visible) row and makes the row visible. But the program stops with
> a java.lang.StackOverflowError.
> Thanks in advance.
> Regards
> Tino
> import org.eclipse.swt.widgets.Display;
> newInput) {
> public int counter;
> super(viewer);
> return true;
> return cellEditor;
> @Override
> @Override
> // Writable columns
> @Override
> @Override
> @Override
> || event.eventType ==
> || (event.eventType ==
> ColumnViewerEditorActivationEvent.KEY_PRESSED && event.keyCode == SWT.CR);
> v.setInput(model);
> return elements;
> * @param args
> public static void main(String[] args) {
> new Snippet(shell);
> shell.open();
> display.sleep();
> display.dispose();
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: StackOverflowError by traversing a table [message #60485 is a reply to message #60465] Mon, 17 November 2008 10:25 Go to previous messageGo to next message
Hi Tom,
tnx for your fast answer. I'm using JFace 3.4.1. So, I give the
header_footer branch a try.
Do I have to use another JFace version than 3.4.1 in combination with this
branch?
Re: StackOverflowError by traversing a table [message #60504 is a reply to message #60485] Mon, 17 November 2008 10:38 Go to previous messageGo to next message
No.
Tom
Tino schrieb:
> Hi Tom,
> header_footer branch a try. Do I have to use another JFace version than
> 3.4.1 in combination with this branch?
Re: StackOverflowError by traversing a table [message #60522 is a reply to message #60504] Tue, 18 November 2008 04:12 Go to previous message
Hi Tom,
I tested it with the header_footer branch, but it still doesn't work.
So, I created a bugzilla entry:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=255610
Tino
Re: StackOverflowError by traversing a table [message #592708 is a reply to message #60443] Mon, 17 November 2008 08:38 Go to previous message
Tom
Tino schrieb:
> Hello,
> Thanks in advance.
> Regards
> Tino
> newInput) {
> public int counter;
> super(viewer);
> return true;
> return cellEditor;
> @Override
> @Override
> // Writable columns
> @Override
> @Override
> @Override
> || event.eventType ==
> || (event.eventType ==
> v.setInput(model);
> return elements;
> * @param args
> new Snippet(shell);
> shell.open();
> display.sleep();
> display.dispose();
Re: StackOverflowError by traversing a table [message #592724 is a reply to message #60465] Mon, 17 November 2008 10:25 Go to previous message
Hi Tom,
branch?
Re: StackOverflowError by traversing a table [message #592729 is a reply to message #60485] Mon, 17 November 2008 10:38 Go to previous message
No.
Tom
Tino schrieb:
> Hi Tom,
Re: StackOverflowError by traversing a table [message #592741 is a reply to message #60504] Tue, 18 November 2008 04:12 Go to previous message
Hi Tom,
Tino
Previous Topic:StackOverflowError by traversing a table
Next Topic:GalleryTreeViewer: GalleryItem description with ListItemRenderer
Current Time: Mon Oct 27 18:43:46 EDT 2025
Powered by FUDForum. Page generated in 0.05508 seconds
