Home » Eclipse Projects » Eclipse Platform » VM Exception when starting in debug mode
VM Exception when starting in debug mode [message #60418] Tue, 03 June 2003 09:41
Originally posted by: stephan.huber.fja.com
Has anybody an idea what to do to avoid the following exception.
It happens most of the time when starting the project in debug mode.
Stephan
An unexpected exception has been detected in native code outside the VM.
Unexpected Signal : EXCEPTION_ACCESS_VIOLATION occurred at PC=0x6d28b883
Function name=(N/A)
Library=(N/A)
NOTE: We are unable to locate the function name symbol for the error
just occurred. Please refer to release documentation for possible
reason and solutions.
Current Java thread:
at java.lang.ClassLoader.findBootstrapClass(Native Method)
at java.lang.ClassLoader.findBootstrapClass0(ClassLoader.java:7 09)
at java.lang.ClassLoader.loadClass(ClassLoader.java:289)
- locked <2cf1778> (a sun.misc.Launcher$ExtClassLoader)
at java.lang.ClassLoader.loadClass(ClassLoader.java:287)
- locked <2ced898> (a sun.misc.Launcher$AppClassLoader)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:281 )
at java.lang.ClassLoader.loadClass(ClassLoader.java:250)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:310 )
at com.inprise.vbroker.orb.ORB$2.create(ORB.java:797)
com.inprise.vbroker.ProtocolEngine.GenericSCM.<init>(GenericSCM.java:73)
at com.inprise.vbroker.orb.SocketSCM.<init>(SocketSCM.java:147)
at com.inprise.vbroker.orb.ORB$5.create(ORB.java:814)
com.inprise.vbroker.ProtocolEngine.ServerEngineImpl.<init>(ServerEngineImpl.java:107)
at com.inprise.vbroker.orb.ORB$1.create(ORB.java:791)
com.inprise.vbroker.ProtocolEngine.ManagerImpl.getServerEngi ne(ManagerImpl.java:182)
- locked <2d74870> (a com.inprise.vbroker.ProtocolEngine.ManagerImpl)
at com.inprise.vbroker.poa.POAImpl.<init>(POAImpl.java:303)
com.inprise.vbroker.poa.AdapterManager.createRootPOA(Adapter Manager.java:55)
at com.inprise.vbroker.poa.AdapterManager.rootPOA(AdapterManage r.java:78)
- locked <2d77fa0> (a com.inprise.vbroker.poa.AdapterManager)
com.inprise.vbroker.poa.AdapterManager$1.resolve(AdapterMana ger.java:268)
com.inprise.vbroker.interceptor.InterceptorManagerImpl$Servi ceManager.resolve(InterceptorManagerImpl.java:87)
at com.inprise.vbroker.orb.ORB.resolve_initial_references(ORB.j ava:710)
at com.fja.lf.kbf.fs.srv.KbfServer.run(KbfServer.java:75)
at com.fja.vkb.kbf.fs.srv.KbfServerVKB.main(KbfServerVKB.java:4 7)
Dynamic libraries:
0x00400000 - 0x00405000 E:\Programme\jdk1.3.1\bin\javaw.exe
0x77F70000 - 0x77FD0000 D:\WINNT\System32\ntdll.dll
0x77DC0000 - 0x77DFF000 D:\WINNT\system32\ADVAPI32.dll
0x77F00000 - 0x77F62000 D:\WINNT\system32\KERNEL32.dll
0x77E70000 - 0x77EC2000 D:\WINNT\system32\USER32.dll
0x77ED0000 - 0x77EFC000 D:\WINNT\system32\GDI32.dll
0x77E10000 - 0x77E67000 D:\WINNT\system32\RPCRT4.dll
0x78000000 - 0x78044000 D:\WINNT\system32\MSVCRT.dll
0x6D420000 - 0x6D4F8000 E:\Programme\jdk1.3.1\jre\bin\hotspot\jvm.dll
0x77FD0000 - 0x77FFB000 D:\WINNT\System32\WINMM.dll
0x6BD00000 - 0x6BD14000 D:\WINNT\System32\cm-pci.dll
0x6D220000 - 0x6D227000 E:\Programme\jdk1.3.1\jre\bin\hpi.dll
0x6D3B0000 - 0x6D3BD000 E:\Programme\jdk1.3.1\jre\bin\verify.dll
0x6D250000 - 0x6D267000 E:\Programme\jdk1.3.1\jre\bin\java.dll
0x6D3C0000 - 0x6D3CD000 E:\Programme\jdk1.3.1\jre\bin\zip.dll
0x6D2A0000 - 0x6D2BB000 E:\Programme\jdk1.3.1\jre\bin\jdwp.dll
0x6D1D0000 - 0x6D1D5000 E:\Programme\jdk1.3.1\bin\dt_socket.dll
0x776A0000 - 0x776B4000 D:\WINNT\System32\ws2_32.dll
0x77690000 - 0x77697000 D:\WINNT\system32\WS2HELP.dll
0x74FD0000 - 0x74FDE000 D:\WINNT\System32\rnr20.dll
0x5F7F0000 - 0x5F7F7000 D:\WINNT\System32\rpcltc1.dll
0x77650000 - 0x7765F000 D:\WINNT\system32\msafd.dll
0x77680000 - 0x77689000 D:\WINNT\System32\wshtcpip.dll
0x776C0000 - 0x776C8000 D:\WINNT\system32\WSOCK32.dll
0x6D340000 - 0x6D348000 E:\Programme\jdk1.3.1\jre\bin\net.dll
0x6D240000 - 0x6D246000 E:\Programme\jdk1.3.1\jre\bin\ioser12.dll
0x76AE0000 - 0x76AFD000 D:\WINNT\System32\imagehlp.dll
0x690A0000 - 0x690AB000 D:\WINNT\System32\PSAPI.DLL
Local Time = Tue Jun 03 15:32:42 2003
Elapsed Time = 73
# The exception above was detected in native code outside the VM
# Java VM: Java HotSpot(TM) Client VM (1.3.1_08-b03 interpreted mode)
# An error report file has been saved as hs_err_pid436.log.
# Please refer to the file for further information.
Previous Topic:searching resources in jar files
Next Topic:Different folder for plug-ins
Current Time: Fri Jul 18 00:43:27 EDT 2025
Powered by FUDForum. Page generated in 0.24231 seconds
