Home » Eclipse Projects » Nebula » GridColumn visibility problem
GridColumn visibility problem [message #60395] Thu, 13 November 2008 11:52 Go to next message
I've read that the column (in)visibility is still under construction, but
I have to hide some columns and when I do it I get some issues. I couldn't
think out how to do this on other way. I need to be able to set some
columns invisible (and visible again), but the Grid doesn't behave
adequately. First of all, when I move through the grid with the arrows and
the selection exits the visible area, the grid doesn't scroll. And second
of all (and the badest) when the first column (index 0) is hidden and the
focused cell is in the first visible column, when the left arrow key is
pressed, I get NullPointerException from the method Grid.showColumn(). Can
you tell me some other way to hide columns and avoid these issues.
Here's an example snippet of these ussiues:
http://acho.ignatov.googlepages.com/GridBugSnippet.jar
And here's the code of the example snippet:
http://acho.ignatov.googlepages.com/GridBugSnippet_src.zip
Thank you in advance and sorry for my not-very-good English.
Re: GridColumn visibility problem [message #60421 is a reply to message #60395] Thu, 13 November 2008 12:04 Go to previous messageGo to next message
I think I fixed such an issue in my header_footer code base you find in
CVS. Could you please file a bug and I'll try to fix it.
Tom
> but I have to hide some columns and when I do it I get some issues. I
> couldn't think out how to do this on other way. I need to be able to set
> some columns invisible (and visible again), but the Grid doesn't behave
> and the selection exits the visible area, the grid doesn't scroll. And
> second of all (and the badest) when the first column (index 0) is hidden
> and the focused cell is in the first visible column, when the left arrow
> key is pressed, I get NullPointerException from the method
> Grid.showColumn(). Can you tell me some other way to hide columns and
> avoid these issues.
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: GridColumn visibility problem [message #61229 is a reply to message #60395] Thu, 11 December 2008 20:28 Go to previous message
the way I hide columns is using
setWidth(0);
settResizeable(false);
Re: GridColumn visibility problem [message #592686 is a reply to message #60395] Thu, 13 November 2008 12:04 Go to previous message
Tom
> avoid these issues.
Re: GridColumn visibility problem [message #592965 is a reply to message #60395] Thu, 11 December 2008 20:28 Go to previous message
setWidth(0);
Previous Topic:Grid - Grid Colunm
Next Topic:Gallery image loading question
Current Time: Sat Nov 15 09:45:32 EST 2025
Powered by FUDForum. Page generated in 0.04777 seconds
