Home » Eclipse Projects » Plugin Development Environment (PDE) » [target] Adding a feature
[target] Adding a feature [message #60301] Fri, 08 May 2009 11:57 Go to next message
I'm confused about what adding a Feature to a target means.
I added the org.eclipse.platform feature from ${eclipse_home}. But that
didn't get me any of the dependencies of the plug-ins included in that
feature. For example, org.eclipse.core.runtime was not included.
Is that how its supposed to work? Is there an easier way to include the
platform feature and all its dependencies?
Cheers
Ben
Re: [target] Adding a feature [message #60352 is a reply to message #60301] Sun, 10 May 2009 05:01 Go to previous messageGo to next message
> Cheers
> Ben
That is because the o.e.core.runtime is part of the Eclipse RCP feature (org.eclipse.rcp) and not
the platform feature.
You are already using the easiest way!! :)
hth,
Ankur..
Re: [target] Adding a feature [message #60923 is a reply to message #60352] Mon, 11 May 2009 09:53 Go to previous message
> (org.eclipse.rcp) and not the platform feature.
Thank you :)
Re: [target] Adding a feature [message #597097 is a reply to message #60301] Sun, 10 May 2009 05:01 Go to previous message
> Cheers
> Ben
hth,
Ankur..
Re: [target] Adding a feature [message #597193 is a reply to message #60352] Mon, 11 May 2009 09:53 Go to previous message
Thank you :)
Previous Topic:Problem upgrading existing automated build to use eclipse 3.5 (related to p2?)
Next Topic:Access information about existing Java projects in the workspace
Current Time: Thu Nov 06 06:57:58 EST 2025
Powered by FUDForum. Page generated in 0.03619 seconds
