| JUnit question in Eclipse [message #60290] |
Tue, 23 December 2003 12:59  |
Originally posted by: no.spam.com
I'm in the process of trying to learn JUnit, and integrate some tests
into one of my applications.
The problem that I am having is that when I run this as a JUnit test
from Eclipse, it executes my setUp() method once for every method that
starts with test... instead of just calling it once for all tests in
this class. My actual setUp method is kind of expensive, so I don't
want to do it multiple times.
Apologies if this is off topic, or if I am missing something really
simple... but I can't seem to figure it out. Any help would be
appreciated. My basic class structure is below.
Dan
My test class currently looks something like this:
public class TestBrowserOperations extends TestCase
private BrowserOperations boi_;
public static void main(String[] args)
protected void setUp() throws Exception
boi_ = //do the setup...
protected void tearDown() throws Exception
boi_ = null;
super.tearDown();
public void testGetCTSVersion() throws Exception
assertNotNull(boi_.getCTSVersion());
public void testGetServiceDescription() throws Exception
assertNotNull(boi_.getServiceDescription());
| Re: JUnit question in Eclipse *off topic* [message #60338 is a reply to message #60314] |
Tue, 23 December 2003 16:36   |
Thanks. I set up a new class to hold a single instance of my object
that is expensive to build... so it can be reused. This fixed it... but
it seems like such a hack.
What is the accepted way to do something expensive (like create
connections to an ldap server, read prefererences from disk, etc) and
reuse this in all of the test cases?
This seems like it would be a pretty common issue. I guess I should
probably move over to the JUnit mailing lists.
Dan
David Owens II wrote:
> That is not an Eclipse issue; that is how JUnit works. The setup method
> is supposed to be called before each test is run. The setup method is
> used to put the test grounds into a known state. But if you really only
> want to call it once (not recommended), you can create an internal-class
> and put your test methods there. Then the setup() function will only be
> called once (checkout the JUnit FAQ - junit.org - for more info on that).
> Good luck!
> David
>> Thanks,
>> Dan
>> boi_ = null;
>> super.tearDown();
| Re: JUnit question in Eclipse *off topic* [message #60362 is a reply to message #60338] |
Tue, 23 December 2003 20:55   |
Originally posted by: davidoii.hotmail.com
You're right, it is a hack and it's not considered good testing style.
If you want to create a connection or something of the sort, just put it
in the constructor of the test class. This will be called only once.
Hope that helps!
David
> Dan
>> method is supposed to be called before each test is run. The setup
>> method is used to put the test grounds into a known state. But if you
>> really only want to call it once (not recommended), you can create an
>> internal-class and put your test methods there. Then the setup()
>> function will only be called once (checkout the JUnit FAQ - junit.org
>> Good luck!
>> David
>>> that starts with test... instead of just calling it once for all
>>> tests in this class. My actual setUp method is kind of expensive, so
>>> I don't want to do it multiple times.
>>> Thanks,
>>> Dan
>>> boi_ = null;
>>> super.tearDown();
| Re: JUnit question in Eclipse *off topic* [message #60984 is a reply to message #60338] |
Wed, 14 January 2004 19:05  |
Originally posted by: rtayek.no.spam.freightgate.com
"Dan Armbrust" <no@spam.com> wrote in message
news:bsach6$n2d$1@eclipse.org...
> it seems like such a hack. ...
> ...This seems like it would be a pretty common issue. I guess I should
yes, iirc, it was a recent thread and perhaps a class was uploaded. maybe
try the archives.
| Re: JUnit question in Eclipse [message #596248 is a reply to message #60290] |
Tue, 23 December 2003 15:07  |
Good luck!
David
> Dan
> boi_ = null;
> super.tearDown();
| Re: JUnit question in Eclipse *off topic* [message #596259 is a reply to message #60314] |
Dan
> Good luck!
> David
>> Thanks,
>> Dan
>> boi_ = null;
>> super.tearDown();
| Re: JUnit question in Eclipse *off topic* [message #596266 is a reply to message #60338] |
Hope that helps!
David
> Dan
>> Good luck!
>> David
>>> Thanks,
>>> Dan
>>> boi_ = null;
>>> super.tearDown();
| Re: JUnit question in Eclipse *off topic* [message #596420 is a reply to message #60338] |
try the archives.
FUDForum. Page generated in 0.04767 seconds
