Home » Modeling » GMF (Graphical Modeling Framework) » Validating notation.genmodel
Validating notation.genmodel [message #60221] Fri, 06 October 2006 10:17
Hey,
Problems while generating code
InvocationTargetException
I've gone into each model to validate them, all fine except for
notation.genmodel, here I get:
Diagnosis of notation
The required feature 'ecoreDataType' of 'Sorting' must be set
The required feature 'ecoreDataType' of 'Filtering' must be set
The required feature 'ecoreDataType' of 'Routing' must be set
The required feature 'ecoreDataType' of 'Smoothness' must be set
The required feature 'ecoreDataType' of 'JumpLinkStatus' must be set
The required feature 'ecoreDataType' of 'JumpLinkType' must be set
The required feature 'ecoreDataType' of 'Alignment' must be set
The required feature 'ecoreDataType' of 'SortingDirection' must be set
The required feature 'ecoreDataType' of 'MeasurementUnit' must be set
Examining these in the property view of within Notation I can't see any
reference to a 'ecoreDataType', Ecore at root, containing Enum, containing
Default Value, Instance Class Namem, Name, Serialzable.
Other problems I encoutered (to get to this point), that I fixed, but how
I did so might be causing the problem are:
The required feature 'diagramLabel': which I set
The required feature 'targetMetaFeature': which I set
Does the notation.genmodel need to work/validate?
What am I doing when I actually set 'diagramLabel' and
'targetMetaFeature'? Have a feeling that how I set these is part of the
problem.
Previous Topic:Copy GMF diagram coordinates to model
Next Topic:does the notation model extend the ecore model?
Current Time: Sun Jul 27 03:09:18 EDT 2025
Powered by FUDForum. Page generated in 0.04218 seconds
