Home » Language IDEs » AspectJ » How to retrieve method name in a handle clause
How to retrieve method name in a handle clause [message #60208] Fri, 06 January 2006 10:42 Go to next message
Originally posted by: philippe.larouche.cardinal.com
Hi guys, I want to log some info in a file each time an exception is thrown
and one info that I'm interested in is the method's name where the exception
has been handled. The problem is that in an handle clause, I'm not able to
retrieve my method name. Here's how I defined the pointcut
pointcut logging(Exception exception) :
handler(!MyException) && args(exception);
I want to log everytime an exception (that is not a MyException instance) is
thrown.
Can someone help me please?? I tried to retrieve the info by the signature,
but it doesn't work.
Phil
Re: How to retrieve method name in a handle clause [message #60281 is a reply to message #60208] Mon, 09 January 2006 04:15 Go to previous messageGo to next message
> thrown.
> Phil
You can use the special variable "thisEnclosingJoinPointStaticPart"
inside the body of an advice method. In the case of a handler join
point, the enclosing join point will be a method or constructor
execution join point, from which you can get the method name etc.
Regards, Adrian.
Re: How to retrieve method name in a handle clause [message #60329 is a reply to message #60281] Mon, 09 January 2006 13:26 Go to previous message
Thx, it's exactly what I wanted to do... It works perfectly.
"Adrian Colyer" <adrian.colyer@gmail.com> wrote in message
news:dpt9ka$575$2@utils.eclipse.org...
>> thrown and one info that I'm interested in is the method's name where the
>> exception has been handled. The problem is that in an handle clause, I'm
>> not able to retrieve my method name. Here's how I defined the pointcut
>> is thrown.
>> signature, but it doesn't work.
>> Thanks,
>> Phil
> You can use the special variable "thisEnclosingJoinPointStaticPart" inside
> the body of an advice method. In the case of a handler join point, the
> enclosing join point will be a method or constructor execution join point,
> Regards, Adrian.
Re: How to retrieve method name in a handle clause [message #591641 is a reply to message #60208] Mon, 09 January 2006 04:15 Go to previous message
> thrown.
> Phil
Regards, Adrian.
Re: How to retrieve method name in a handle clause [message #591657 is a reply to message #60281] Mon, 09 January 2006 13:26 Go to previous message
>> is thrown.
>> Thanks,
>> Phil
> Regards, Adrian.
Previous Topic:Eclipse AspectJ Newbie Problem
Next Topic:AJDT is slow
Current Time: Tue Jul 22 01:40:40 EDT 2025
Powered by FUDForum. Page generated in 0.07275 seconds
