Home » Eclipse Projects » Remote Application Platform (RAP) » An entry point named 'default' does not exist.
An entry point named 'default' does not exist. [message #60196] |
Fri, 16 November 2007 09:27  |
sgi> 15:22:38,703 ERROR [[equinoxbridgeservlet]] Servlet.service() for servlet
equinoxbridgeservlet threw exception
java.lang.IllegalArgumentException: An entry point named 'default' does
not exist.
org.eclipse.rwt.internal.lifecycle.EntryPointManager.createU I(EntryPointManager.java:80)
org.eclipse.rwt.internal.lifecycle.PrepareUIRoot.execute(Pre pareUIRoot.java:36)
org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.executePhase (RWTLifeCycle.java:126)
org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.execute(RWTL ifeCycle.java:88)
org.eclipse.rwt.internal.service.LifeCycleServiceHandler$1.r un(LifeCycleServiceHandler.java:59)
org.eclipse.rwt.internal.service.LifeCycleServiceHandler.int ernalService(LifeCycleServiceHandler.java:178)
org.eclipse.rwt.internal.service.LifeCycleServiceHandler.acc ess$1(LifeCycleServiceHandler.java:170)
org.eclipse.rwt.internal.service.LifeCycleServiceHandler$Lif eCycleServiceHandlerSync.doService(LifeCycleServiceHandler.j ava:135)
org.eclipse.rwt.internal.lifecycle.RWTLifeCycleServiceHandle rSync.serviceInternal(RWTLifeCycleServiceHandlerSync.java:82 )
org.eclipse.rwt.internal.lifecycle.RWTLifeCycleServiceHandle rSync.access$0(RWTLifeCycleServiceHandlerSync.java:48)
org.eclipse.rwt.internal.lifecycle.RWTLifeCycleServiceHandle rSync$1.service(RWTLifeCycleServiceHandlerSync.java:43)
org.eclipse.rwt.internal.lifecycle.RWTLifeCycleBlockControl$ ServiceHandlerProcessor.run(RWTLifeCycleBlockControl.java:68 )
org.eclipse.rwt.internal.lifecycle.RWTLifeCycleThreadPool$Po olRunnable.run(RWTLifeCycleThreadPool.java:38)
org.eclipse.rwt.internal.lifecycle.RWTLifeCycleThreadPool$Po olWorker.run(RWTLifeCycleThreadPool.java:66)
What's wrong? This is only a copy of the rapdemo-project from cvs which
have the same error when starting from my jboss server. Out of Eclipse
with the "OSGi Framework Launcher" everythink is fine!
Greetz an thank's for help,
Steffen
Re: An entry point named 'default' does not exist. [message #60317 is a reply to message #60268] |
Mon, 19 November 2007 04:17   |
I have deployed my WAR File on JBOSS4.0.5 Tomcat. Out of Eclipse the demo
work fine!
That's my config.ini:
#Eclipse Runtime Configuration File
osgi.bundles=org.eclipse.core.commands_3.3.0.I20070605-0010.jar@start,
org.eclipse.core.contenttype_3.2.100.v20070319.jar@start,
org.eclipse.core.expressions_3.3.0.v20070606-0010.jar@start,
org.eclipse.core.jobs_3.3.0.v20070423.jar@start,
org.eclipse.core.runtime_3.3.100.v20070530.jar@start,
org.eclipse.equinox.app_1.0.0.v20070606.jar@start,
org.eclipse.equinox.common_3.3.0.v20070426.jar@2:start,
org.eclipse.equinox.http.registry_1.0.0.20071010-2241.jar@start,
org.eclipse.equinox.http.servletbridge_1.0.0.200711190829.ja r @start,
org.eclipse.equinox.http.servlet_1.0.0.20071010-2241.jar@start,
org.eclipse.equinox.preferences_3.2.100.v20070522.jar@start,
org.eclipse.equinox.registry_3.3.0.v20070522.jar@start,
org.eclipse.osgi.services_3.1.200.v20070605.jar@start,
org.eclipse.rap.demo_1.0.1.jar@start,
org.eclipse.rap.jface_1.0.0.20071010-2241.jar@start,
org.eclipse.rap.rwt_1.0.0.20071010-2241.jar@start,
org.eclipse.rap.ui.workbench_1.0.0.20071010-2241.jar@start,
org.eclipse.rap.ui_1.0.0.20071010-2241.jar@start,
org.eclipse.update.configurator_3.2.200.200711190829.jar@start
osgi.bundles.defaultStartLevel=4
Re: An entry point named 'default' does not exist. [message #60341 is a reply to message #60317] |
Mon, 19 November 2007 06:38   |
Originally posted by: fappel.innoopract.com
could you please add the OSGi console log file, to see whether anything went
wrong on bundle activation? (The log file is located in the workspace
directory of you OSGi instance, which is located in the work directory of
the application context...)
Ciao
Frank
"Steffen" <steffen.peil@we4it.com> schrieb im Newsbeitrag
news:c0f0741ca5ef7dd53eff144dbadd2011$1@www.eclipse.org...
>work fine!
Re: An entry point named 'default' does not exist. [message #61486 is a reply to message #60341] |
Wed, 21 November 2007 06:16   |
I hope it's the correct Log-File.
2007-11-21 12:05:59,465 INFO [org.jboss.system.server.Server] JBoss (MX
MicroKernel) [4.0.5.GA (build: CVSTag=Branch_4_0 date=200610162339)]
Started in 19s:922ms
2007-11-21 12:09:43,996 INFO [STDOUT] Framework is launched.
2007-11-21 12:09:43,996 INFO [STDOUT] id
2007-11-21 12:09:43,996 INFO [STDOUT] State Bundle
2007-11-21 12:09:43,996 INFO [STDOUT] 0 ACTIVE
system.bundle_3.2.2.R32x_v20070118
2007-11-21 12:09:43,996 INFO [STDOUT] Fragments=
2007-11-21 12:09:43,996 INFO [STDOUT] 32
2007-11-21 12:09:43,996 INFO [STDOUT] 1 ACTIVE
org.eclipse.core.commands_3.2.0.I20060605-1400
2007-11-21 12:09:43,996 INFO [STDOUT] 2 ACTIVE
org.eclipse.core.contenttype_3.2.0.v20060603
2007-11-21 12:09:43,996 INFO [STDOUT] 3 ACTIVE
org.eclipse.core.jobs_3.2.0.v20060603
2007-11-21 12:09:43,996 INFO [STDOUT] 4 ACTIVE
org.eclipse.core.runtime_3.2.0.v20060603
2007-11-21 12:09:43,996 INFO [STDOUT] 5 ACTIVE
org.eclipse.equinox.common_3.2.0.v20060603
2007-11-21 12:09:43,996 INFO [STDOUT] 6 ACTIVE
org.eclipse.equinox.http.registry_1.0.0.200705071244
2007-11-21 12:09:43,996 INFO [STDOUT] 7 ACTIVE
org.eclipse.equinox.http.servletbridge_1.0.0.200705071244
2007-11-21 12:09:43,996 INFO [STDOUT] 8 ACTIVE
org.eclipse.equinox.http.servlet_1.0.0.200705071244
2007-11-21 12:09:43,996 INFO [STDOUT] 9 ACTIVE
org.eclipse.equinox.preferences_3.2.1.R32x_v20060717
2007-11-21 12:09:43,996 INFO [STDOUT] 10 ACTIVE
org.eclipse.equinox.registry_3.2.1.R32x_v20060814
2007-11-21 12:09:43,996 INFO [STDOUT] 11 ACTIVE
org.eclipse.osgi.services_3.1.100.v20060601
2007-11-21 12:09:43,996 INFO [STDOUT] 12 ACTIVE
com.we4it.seminar.web_1.0.0
2007-11-21 12:09:43,996 INFO [STDOUT] 13 ACTIVE
2007-11-21 12:09:43,996 INFO [STDOUT] 14 ACTIVE
2007-11-21 12:09:43,996 INFO [STDOUT] 15 ACTIVE
org.eclipse.rap.jface_1.0.0.200705071244
2007-11-21 12:09:43,996 INFO [STDOUT] 16 ACTIVE
org.eclipse.rap.rwt_1.0.0.200705071244
2007-11-21 12:09:43,996 INFO [STDOUT] 17 ACTIVE
org.eclipse.rap.ui.workbench_1.0.0.200705071244
2007-11-21 12:09:43,996 INFO [STDOUT] 18 ACTIVE
org.eclipse.rap.w4t_1.0.0.200705071244
2007-11-21 12:09:43,996 INFO [STDOUT] 19 ACTIVE
org.eclipse.update.configurator_3.2.2.R32x_v20070111
2007-11-21 12:09:43,996 INFO [STDOUT] 32 RESOLVED
org.eclipse.equinox.servletbridge.extensionbundle_1.0.0
2007-11-21 12:09:43,996 INFO [STDOUT] Master=0
osgi>
2007-11-21 12:10:07,059 ERROR [STDERR] java.lang.IllegalArgumentException:
2007-11-21 12:10:07,059 ERROR [STDERR] at
org.eclipse.swt.internal.lifecycle.EntryPointManager.createU I(EntryPointManager.java:70)
org.eclipse.swt.internal.lifecycle.PrepareUIRoot.execute(Pre pareUIRoot.java:32)
org.eclipse.swt.internal.lifecycle.RWTLifeCycle.execute(RWTL ifeCycle.java:60)
com.w4t.engine.W4TModel$ServiceAdapter.execute(W4TModel.java :47)
com.w4t.engine.service.FormRequestServiceHandler.service(For mRequestServiceHandler.java:65)
com.w4t.engine.service.ServiceManager$HandlerDispatcher.serv ice(ServiceManager.java:90)
com.w4t.engine.W4TDelegate.doPost(W4TDelegate.java:75)
org.eclipse.ui.internal.servlet.RequestHandler.service(Reque stHandler.java:41)
javax.servlet.http.HttpServlet.service(HttpServlet.java:810)
org.eclipse.equinox.http.registry.internal.ServletManager$Se rvletWrapper.service(ServletManager.java:177)
org.eclipse.equinox.http.servlet.internal.ServletRegistratio n.handleRequest(ServletRegistration.java:91)
org.eclipse.equinox.http.servlet.internal.ProxyServlet.proce ssAlias(ProxyServlet.java:110)
org.eclipse.equinox.http.servlet.internal.ProxyServlet.servi ce(ProxyServlet.java:60)
org.eclipse.equinox.servletbridge.BridgeServlet.service(Brid geServlet.java:115)
org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:252)
org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:173)
org.jboss.web.tomcat.filters.ReplyHeaderFilter.doFilter(Repl yHeaderFilter.java:96)
org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:202)
org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:213)
org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:178)
org.jboss.web.tomcat.security.SecurityAssociationValve.invok e(SecurityAssociationValve.java:175)
org.jboss.web.tomcat.security.JaccContextValve.invoke(JaccCo ntextValve.java:74)
org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:126)
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorRepo rtValve.java:105)
org.jboss.web.tomcat.tc5.jca.CachedConnectionValve.invoke(Ca chedConnectionValve.java:156)
org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:107)
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAd apter.java:148)
org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:869)
org.apache.coyote.http11.Http11BaseProtocol$Http11Connection Handler.processConnection(Http11BaseProtocol.java:664)
org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(Poo lTcpEndpoint.java:527)
org.apache.tomcat.util.net.MasterSlaveWorkerThread.run(Maste rSlaveWorkerThread.java:112)
java.lang.Thread.run(Thread.java:595)
[org.apache.catalina.core.ContainerBase.[jboss.web].[localho st].[/we4it].[equinoxbridgeservlet]]
Servlet.service() for servlet equinoxbridgeservlet threw exception
not exist.
at com.w4t.engine.W4TModel$ServiceAdapter.execute(W4TModel.java :47)
at com.w4t.engine.W4TDelegate.doPost(W4TDelegate.java:75)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:810)
at java.lang.Thread.run(Thread.java:595)
Re: An entry point named 'default' does not exist. [message #61720 is a reply to message #61486] |
Thu, 22 November 2007 01:29   |
your application bundle seems to be com.we4it.seminar.web_1.0.0. Which
entrypoints does it declare in the plugin.xml? And how does the URL look
like you use to access the application?
Ciao
Frank
news:4492758a0a964f0f0d113c9a7123e346$1@www.eclipse.org...
> 2007-11-21 12:09:43,996 INFO [STDOUT] 2007-11-21 12:09:43,996 INFO
> 2007-11-21 12:09:43,996 INFO [STDOUT] osgi> 2007-11-21 12:10:07,059 ERROR
> [STDERR] java.lang.IllegalArgumentException: An entry point named
> not exist.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Current Time: Sun Jul 13 23:56:37 EDT 2025
Powered by FUDForum. Page generated in 0.06839 seconds
