Home » Eclipse Projects » Mylyn » Could not load repository template extension repository
Could not load repository template extension repository [message #60195] Sat, 18 October 2008 10:26 Go to next message
After updating to 3.0.3 I see this message in error log after every
restart. I don't know, may be it was there even with 3.0.2. Does it
means something bad? Howe can I fix this? How can I prevent this?
Eclipse 3.5M2.
Re: Could not load repository template extension repository [message #60315 is a reply to message #60195] Sun, 19 October 2008 14:58 Go to previous messageGo to next message
Originally posted by: steffen.pingel.eclipse.org
Please post the error message.
Steffen
> Eclipse 3.5M2.
Re: Could not load repository template extension repository [message #60339 is a reply to message #60315] Sun, 19 October 2008 16:15 Go to previous messageGo to next message
Steffen Pingel wrote:
Here is full content of .log, as you can see, there are no stack trace.
!SESSION 2008-10-20 00:12:20.796
eclipse.buildId=I20080918-0100
java.version=1.6.0_07
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=ru_RU
Command-line arguments: -os win32 -ws win32 -arch x86 -clean
!ENTRY org.eclipse.mylyn.tasks.ui 4 0 2008-10-20 00:13:09.953
!MESSAGE Could not load repository template extension repository
> Steffen
>> Eclipse 3.5M2.
Re: Could not load repository template extension repository [message #61527 is a reply to message #60195] Tue, 11 November 2008 01:45 Go to previous messageGo to next message
Originally posted by: Manish_Malhotra01.infosys.com
I also got the same issue,
By verifying the Plugin.xml entries with the Trac Plugin.xml.
It got solved, and that was because of the ConnectorUI entry in the <extension
point="org.eclipse.mylyn.tasks.ui.repositories">.
Following are the entries of Trac Connector UI's plugin.
<?eclipse version="3.2"?>
<plugin>
<extension id="org.eclipse.mylyn.trac.repository" name="Trac Repository" point="org.eclipse.mylyn.tasks.ui.repositories">
<connectorCore class=" org.eclipse.mylyn.internal.trac.core.TracRepositoryConnector " id="trac" name="Trac Connector Core"/>
<connectorUi brandingIcon="icons/eview16/trac-icon.gif" class="org.eclipse.mylyn.internal.trac.ui.TracConnectorUi" id="trac" name="Trac Connector UI" overlayIcon="icons/eview16/overlay-trac.gif"/>
<taskListMigrator class="org.eclipse.mylyn.internal.trac.ui.TracTaskListMigrator ">
</taskListMigrator>
</extension>
<extension point="org.eclipse.mylyn.tasks.core.templates">
<repository addAutomatically="false" anonymous="true" label="Edgewall" repositoryKind="trac" urlRepository="http://trac.edgewall.org" version="TRAC_0_9"/>
</extension>
<extension point="org.eclipse.mylyn.tasks.ui.editors">
<pageFactory class=" org.eclipse.mylyn.internal.trac.ui.editor.TracTaskEditorPage Factory " id="org.eclipse.mylyn.trac.ui.pageFactory">
</pageFactory>
</extension>
<extension point="org.eclipse.ui.workbench.texteditor.hyperlinkDetectors ">
<hyperlinkDetector class="org.eclipse.mylyn.internal.trac.ui.TracHyperlinkDetector " id="org.eclipse.mylyn.trac.ui.hyperlinksDetectors.Trac" name="Trac Links" targetId="org.eclipse.mylyn.tasks.ui.TaskEditor">
</hyperlinkDetector>
</extension>
</plugin>
Hope fully this will help you, if still this problem isnt solved.
I havent used hyperlinkDetector, as I didnt required.
Manish
Re: Could not load repository template extension repository [message #61551 is a reply to message #61527] Tue, 11 November 2008 01:49 Go to previous messageGo to next message
------=_Part_4657_17679875.1226386245780
Content-Type: text/plain; charset=ISO-8859-1
Content-Disposition: inline
XML content was not published :(
So, find the plugin.xml as an attachment.
cheers,
Manish
Content-Type: application/octet-stream; name=plugin.xml
Content-Disposition: attachment; filename=plugin.xml
<plugin>
</taskListMigrator>
</extension>
</extension>
</pageFactory>
</extension>
</extension>
</plugin>
------=_Part_4657_17679875.1226386245780--
Re: Could not load repository template extension repository [message #61575 is a reply to message #61551] Tue, 11 November 2008 02:04 Go to previous message
Please file a new bug report and include a list of installed features and
plug-ins (available from Help > About > Configuration Details):
http://www.eclipse.org/mylyn/community/
Thanks.
Steffen
Re: Could not load repository template extension repository [message #594352 is a reply to message #60195] Sun, 19 October 2008 14:58 Go to previous message
Steffen
> Eclipse 3.5M2.
Re: Could not load repository template extension repository [message #594370 is a reply to message #60315] Sun, 19 October 2008 16:15 Go to previous message
> Steffen
>> Eclipse 3.5M2.
Re: Could not load repository template extension repository [message #594724 is a reply to message #60195] Tue, 11 November 2008 01:45 Go to previous message
<plugin>
</taskListMigrator>
</extension>
</extension>
</pageFactory>
</extension>
</extension>
</plugin>
Manish
Re: Could not load repository template extension repository [message #594734 is a reply to message #61527] Tue, 11 November 2008 01:49 Go to previous message
cheers,
Manish
<plugin>
</taskListMigrator>
</extension>
</extension>
</pageFactory>
</extension>
</extension>
</plugin>
Re: Could not load repository template extension repository [message #594742 is a reply to message #61551] Tue, 11 November 2008 02:04 Go to previous message
Thanks.
Steffen
Previous Topic:Mylyn Trac connector mappings for priority and severity fields
Next Topic:Mylyn does not allow to show correct tooltip for launch items
Current Time: Wed Dec 03 11:50:38 EST 2025
Powered by FUDForum. Page generated in 0.20550 seconds
