Home » Eclipse Projects » GEF » Please tell me if this is doable
| Please tell me if this is doable [message #60116] |
Thu, 30 January 2003 10:34  |
Originally posted by: jim.azeltine.indus.com
Here is the challenge:
1. Create a Palette with Group, Text, Label, and Table widgets.
2. Build a display of sets of these widgets from a serialized
representation
of a screen layout, including the text values for the Labels and Table
Column headings, rows and columns.
3. Be able to manipulate the size and screen position of the widgets (by
dragging), change the text content of the Labels.
4. Be able to add new Labels and Texts, to include the text content of the
Labels.
5. Be able to delete Labels and Texts.
6. The size of a containing Group would either be dynamic based on the
movement of the child widgets, or by dragging the boundary.
If this is doable using the existing GEF version, any hints on where to
start
would be appreciated.
Jim
| Re: Please tell me if this is doable [message #60140 is a reply to message #60116] |
Thu, 30 January 2003 11:00   |
GUI builders are sometimes implemented by building the real "widgets"
offscreen, and taking a capture of their appearance. See WSAD 5.0 Swing/AWT
builder for an example of this, built on GEF.
When you say Table widget, if you are referring to the SWT Table, this might
be difficult. I'm not sure if "screen scraping" works for those widgets
when they are offscreen.
"Jim Azeltine" <jim.azeltine@indus.com> wrote in message
news:b1bglq$vb0$1@rogue.oti.com...
> representation
> Labels.
> start
> Jim
| Re: Please tell me if this is doable [message #60187 is a reply to message #60140] |
Thu, 30 January 2003 11:56   |
You did not address the question of text manipulation. I get the
impression that GEF does not deal with a real widget, in the case of a
Label or Text, it would just be a Rectangle, and not be able to contain
any text. This would mean that there would have to be 2 separate steps to
performing an edit, one graphical one, and another to manage the text, is
this the case?
> > representation
> > Labels.
> > start
> > Jim
| Re: Please tell me if this is doable [message #60284 is a reply to message #60187] |
Thu, 30 January 2003 14:54   |
You can edit text in the same way that you can edit text in a Tree. Via
CellEditor. GEF lets you overlay a CellEditor on top of a figure in your
diagram.
news:b1blg4$407$1@rogue.oti.com...
> this the case?
Swing/AWT
might
> > > representation
Table
(by
the
> > > Labels.
to
> > > start
> > > Jim
| Re: Please tell me if this is doable [message #61007 is a reply to message #60284] |
Fri, 31 January 2003 10:44   |
Since I cannot find the method to implement the overlay of a CellEditor on
top of a figure, could you direct me to where I can look this up, or give
direction?
> diagram.
> \"Jim Azeltine\" <jim.azeltine@indus.com> wrote in message
> > this the case?
> > Randy Hudson wrote:
> > > GUI builders are sometimes implemented by building the real \"widgets\"
> Swing/AWT
> might
> > > be difficult. I\'m not sure if \"screen scraping\" works for those
widgets
> > > > representation
> Table
> (by
> the
> > > > Labels.
> to
> > > > start
> > > > Jim
| Re: Please tell me if this is doable [message #61026 is a reply to message #61007] |
Fri, 31 January 2003 11:06  |
Please see the Logic example's Label. Double-click on a label in the
example.
in code: LabelEditPart.performDirectEdit()
news:b1e5ka$peh$1@rogue.oti.com...
> direction?
your
> > diagram.
contain
to
is
> > > this the case?
\"widgets\"
> > Swing/AWT
this
> > might
> widgets
> > > > > representation
and
> > Table
widgets
> > (by
content of
> > the
> > > > > Labels.
the
where
> > to
> > > > > start
> > > > > Jim
Current Time: Fri Nov 21 15:08:25 EST 2025
Powered by FUDForum. Page generated in 0.25077 seconds
