| Unhandled event loop exception [message #60003] |
Wed, 15 October 2008 05:39  |
After many months of trouble free use of Mylyn with EclipsePDT and Trac,
anything related to schedule has started throwing exceptions. I'm seeing
this on both a Linux client and a Windows client.
My (Linux) server is running Trac (version 0.10). I'm not seeing any
problems with the web interface. I haven't updated anything on the server,
so I'm at a bit of a loss as to where the problem lies.
Anyone got any ideas?
My apologies in advance for the long stack traces.
Stack trace (Linux):
eclipse.buildId=M20080221-1800
java.version=1.5.0_16
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_GB
Command-line arguments: -os linux -ws gtk -arch x86
org.eclipse.mylyn.internal.tasks.core.DateRange.isWeekAfterN ext(DateRange.java:125)
org.eclipse.mylyn.internal.tasks.core.DateRange.toString(Dat eRange.java:115)
org.eclipse.mylyn.internal.tasks.ui.views.TaskListToolTip.ge tActivityText(TaskListToolTip.java:273)
org.eclipse.mylyn.internal.tasks.ui.views.TaskListToolTip.cr eateToolTipContentArea(TaskListToolTip.java:475)
at org.eclipse.jface.window.ToolTip.toolTipShow(ToolTip.java:33 2)
at org.eclipse.jface.window.ToolTip.toolTipOpen(ToolTip.java:43 3)
at org.eclipse.jface.window.ToolTip.toolTipCreate(ToolTip.java: 321)
at org.eclipse.jface.window.ToolTip.access$2(ToolTip.java:315)
org.eclipse.jface.window.ToolTip$ToolTipOwnerControlListener .handleEvent(ToolTip.java:580)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1101)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3319)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2971)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
I get the following if I try to pull down the "Scheduled for" drop down list
on the planning pane of a task:
org.eclipse.mylyn.internal.tasks.ui.ScheduleTaskMenuContribu tor.createDateSelectionAction(ScheduleTaskMenuContributor.ja va:227)
org.eclipse.mylyn.internal.tasks.ui.ScheduleTaskMenuContribu tor.getSubMenuManager(ScheduleTaskMenuContributor.java:135)
org.eclipse.mylyn.internal.tasks.ui.ScheduleDatePicker$2.wid getSelected(ScheduleDatePicker.java:122)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:227)
I'm seeing something similar on a Windows box:
java.version=1.6.0_07
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_GB
Command-line arguments: -os win32 -ws win32 -arch x86
Error
Wed Oct 15 10:26:15 BST 2008
org.eclipse.mylyn.internal.tasks.core.ScheduledTaskContainer .getEnd(ScheduledTaskContainer.java:208)
org.eclipse.mylyn.internal.tasks.ui.views.TaskScheduleConten tProvider.getElements(TaskScheduleContentProvider.java:81)
org.eclipse.jface.viewers.StructuredViewer.getRawChildren(St ructuredViewer.java:937)
org.eclipse.jface.viewers.ColumnViewer.getRawChildren(Column Viewer.java:693)
org.eclipse.jface.viewers.AbstractTreeViewer.getRawChildren( AbstractTreeViewer.java:1298)
at org.eclipse.jface.viewers.TreeViewer.getRawChildren(TreeView er.java:378)
org.eclipse.jface.viewers.AbstractTreeViewer.getFilteredChil dren(AbstractTreeViewer.java:615)
org.eclipse.jface.viewers.AbstractTreeViewer.getSortedChildr en(AbstractTreeViewer.java:581)
org.eclipse.jface.viewers.AbstractTreeViewer.updateChildren( AbstractTreeViewer.java:2500)
org.eclipse.jface.viewers.AbstractTreeViewer.internalRefresh Struct(AbstractTreeViewer.java:1829)
org.eclipse.jface.viewers.TreeViewer.internalRefreshStruct(T reeViewer.java:704)
org.eclipse.jface.viewers.AbstractTreeViewer.internalRefresh (AbstractTreeViewer.java:1804)
org.eclipse.jface.viewers.AbstractTreeViewer.internalRefresh (AbstractTreeViewer.java:1760)
org.eclipse.jface.viewers.AbstractTreeViewer.internalRefresh (AbstractTreeViewer.java:1746)
org.eclipse.jface.viewers.StructuredViewer$7.run(StructuredV iewer.java:1433)
org.eclipse.jface.viewers.StructuredViewer.preservingSelecti on(StructuredViewer.java:1368)
org.eclipse.jface.viewers.TreeViewer.preservingSelection(Tre eViewer.java:390)
org.eclipse.jface.viewers.StructuredViewer.preservingSelecti on(StructuredViewer.java:1330)
org.eclipse.jface.viewers.StructuredViewer.refresh(Structure dViewer.java:1431)
at org.eclipse.jface.viewers.ColumnViewer.refresh(ColumnViewer. java:536)
org.eclipse.ui.dialogs.FilteredTree$NotifyingTreeViewer.refr esh(FilteredTree.java:818)
org.eclipse.jface.viewers.StructuredViewer.refresh(Structure dViewer.java:1390)
org.eclipse.ui.dialogs.FilteredTree$NotifyingTreeViewer.refr esh(FilteredTree.java:808)
org.eclipse.jface.viewers.ContentViewer.setContentProvider(C ontentViewer.java:229)
org.eclipse.jface.viewers.StructuredViewer.setContentProvide r(StructuredViewer.java:1583)
org.eclipse.jface.viewers.AbstractTreeViewer.setContentProvi der(AbstractTreeViewer.java:2244)
org.eclipse.jface.viewers.TreeViewer.setContentProvider(Tree Viewer.java:928)
org.eclipse.ui.dialogs.FilteredTree$NotifyingTreeViewer.setC ontentProvider(FilteredTree.java:854)
org.eclipse.mylyn.internal.tasks.ui.views.TaskListView.apply Presentation(TaskListView.java:1063)
org.eclipse.mylyn.internal.tasks.ui.actions.PresentationDrop DownSelectionAction.run(PresentationDropDownSelectionAction. java:82)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:546)
at org.eclipse.jface.action.ActionContributionItem.access$
(ActionContributionItem.java:490)
org.eclipse.jface.action.ActionContributionItem$6.handleEven t(ActionContributionItem.java:443)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
| Re: Unhandled event loop exception [message #60029 is a reply to message #60003] |
Wed, 15 October 2008 14:20  |
The errors you are seeing are triggered by the upcoming switch from daylight
savings time. Here is the corresponding bug report:
248683: NPE in DateRange.isWeekAfterNext()
https://bugs.eclipse.org/bugs/show_bug.cgi?id=248683
We are in the process of building a 3.0.3 release which fixes the bug and
should be available shortly.
In the meantime you can install the latest weekly build which has a fix for
the bug:
http://www.eclipse.org/mylyn/downloads/#weekly
Steffen
> server, so I'm at a bit of a loss as to where the problem lies.
> java.lang.NullPointerException
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> list on the planning pane of a task:
> at
> at
> at
> at
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66) at
> org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1101) at
> org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3319) at
> org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2971) at
> org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389) at
> org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353) at
> org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 19) at
> org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466) at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Error
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 ) at
> at
> at
> at
> at
> at
> at
> at
> at
> at
| Re: Unhandled event loop exception [message #594228 is a reply to message #60003] |
the bug:
Steffen
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Error
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
FUDForum. Page generated in 0.04206 seconds
