Home » Eclipse Projects » GEF » How can install the example project of GEF?
How can install the example project of GEF? [message #59904] Wed, 29 January 2003 15:15 Go to next message
Originally posted by: santtun.jippii.fi
Hi!
I just installed Eclipse and GEF. First problem was this one:
"The wizard can be found at File->New->Other (Control+N), under the
Examples heading". I made a new simple project and I tried to follow the
instructions, but under the "other" I haven't Examples-heading. So what's
wrong and have you any good links, tutorials etc so that I can start with
Eclipse and especially GEF.
Thanks!
Santtu
Re: How can install the example project of GEF? [message #60022 is a reply to message #59904] Wed, 29 January 2003 19:44 Go to previous messageGo to next message
Originally posted by: jim.azeltine.indus.com
You need to also install the separate GEF examples, and restart Eclipse.
Then when you choose File >> New >> Other you should see the Examples
wizard, select GEF and you should see Logic Diagram in the right hand pane.
Santtu wrote:
> Hi!
> Examples heading. I made a new simple project and I tried to follow the
> instructions, but under the other I Examples-heading. So whats
> Thanks!
> Santtu
Re: How can install the example project of GEF? [message #60162 is a reply to message #60022] Thu, 30 January 2003 11:31 Go to previous message
Originally posted by: santtun_invalid.jippii.fi
I have already installed the separate example project. I unzipped the zip to
eclipse folder, BUT I sitll can't see the example heading. I installed
everything at the same time, Eclipse, GEF, example and runtime environment.
Thanks!
Sami
"Jim Azeltine" <jim.azeltine@indus.com> wrote in message
news:b19sgs$pdo$1@rogue.oti.com...
pane.
> Santtu wrote:
> > Hi!
with
> > Thanks!
> > Santtu
Previous Topic:How to implement the Model in GEF
Next Topic:Drag and Drop creation
Current Time: Wed Jul 16 04:38:59 EDT 2025
Powered by FUDForum. Page generated in 0.28026 seconds
