Home » Eclipse Projects » Eclipse Platform » Can I get Eclipse to ignore CVS?
Can I get Eclipse to ignore CVS? [message #59838] Mon, 02 June 2003 18:22 Go to next message
Originally posted by: jason.schwab.storagealliance.com
I'm just starting to use Eclipse and really like it, but have been having a
strange problem that I can't seem to resolve.
On our current project we are running CVS, but not in any server mode just
pointing WinCVS at the cvsroot directory. Basically I want Eclipse to
ignore the fact that CVS is happening in the background.
When I create the project in Eclipse though, it recognizes the CVS
directories and adds them into my Package Explorer (I'll see web.servlet
package, and another branch called web.servlet.CVS). Which isn't a big deal
and I could ignore that, but it seems to cause other problems.
Every time a new class is added into CVS and I get it via WinCVS, I have to
refresh the project to get Eclipse to see the new class. Well every time I
do that, if I go into my target directory where my classes get compiled to,
the Entries files for CVS get changed to see the .java files in there!
So I'll have project/src/package/asdf.java and
project/classes/package/asdf.class, but the local CVS folders under my
classes folder (not anywhere else) get changed so they think that there's a
project/classes/package/asdf.java file too.
I'm not really sure what it is trying to do with making those changes.
It's difficult to explain. Anyway, any suggestions on how to get Eclipse to
basically "ignore" any local CVS directories and pretend it's just a local
project and leave the CVS to something else?
Thanks in advance.
Re: Can I get Eclipse to ignore CVS? [message #60461 is a reply to message #59838] Tue, 03 June 2003 09:53 Go to previous messageGo to next message
Originally posted by: bob.news.gmx.net
"Jason Schwab" <jason.schwab@storagealliance.com> schrieb im Newsbeitrag
news:bbgips$e4q$2@rogue.oti.com...
having a
just
to
time I
to,
there's a
Well, eclipse thinks it is modifying the file system alone. So,
naturally, it does not recognize file system changes done by any other
tool. However, there's an experimental plugin that checks the file system
every n minutes - but this is just a workaround and slows things down
considerably.
Eclipse to
local
AFAIK there is no support for serverless CVS in eclipse. The best
solution is to install a server (available for many platforms) and let
eclipse use that.
Cheers
robert
Re: Can I get Eclipse to ignore CVS? [message #65666 is a reply to message #59838] Fri, 06 June 2003 11:33 Go to previous message
Leave the CVS Repositories perspective open. It will ignore CVS related
directories and files even though you aren't using Eclipse' built in CVS
support.
> Thanks in advance.
Previous Topic:Which plug in is for...
Next Topic:Running on RHL 7.3
Current Time: Tue Jul 15 06:33:35 EDT 2025
Powered by FUDForum. Page generated in 0.06804 seconds
