Home » Eclipse Projects » GEF » Problem with LogicDesigner Plugin Source Code in GEF I20030107
Problem with LogicDesigner Plugin Source Code in GEF I20030107 [message #59828] |
Wed, 29 January 2003 14:19  |
Originally posted by: dinkloh.ipd.uni-karlsruhe.de
Hello!
We are using LogicDesigner Plugin in GEF 2.0.1 Build I20030107 with all
three zip files (SDK, runtime, source) installed, because this is the only
version that works with the most current Omondo EclipseUML (www.omondo.com)
Plugin 1.1.7. The API seems to frequently change, but our current problem is
that the LogicDesigner example source code of this particular version does
not seem to work in the runtime-workbench. Did anybody else notice this
also?
I create a new Java project "LogicExample" and set the source directory to
src and the output to bin and added the appropriate libraries. Then I import
the source code from the Zip file from
<eclipse> \plugins\org.eclipse.gef.examples.source_2.0.1\src\org.eclip se.gef.
examples.logic_2.0.1\runtime\
of the above metioned version into LogicExample\src. Since the plugin.xml,
logic.gif, and plugin.properties are still missing I import these from the
directory with the compiled logicdesigner example
<eclipse>\plugins\org.eclipse.gef.examples.logic_2.0.1\
Then I build the project and checked positive that all class files were
created and started a Runtime Workbench with all plugins enabled. Since the
compiled example is existant it gives me an error message that there are
duplicate plugins and the ones from the workbench will be used. That is
exactly what I want to I click OK.
In the Runtime Workbench, when I select New->Examples->GEF->Logic Diagram
the Wizard starts, but has the "Next>" button grey. After clicking on
"Finish", the Wizard windows does not close and nothing happens. I select
"Cancel" and try the same procedure again. Then I look at the Eclipse log
under Help->About Eclipse Platform->Configuration details. I actually looked
in the log file in between, too, so I know that the first call causes the
error message
java.lang.ExceptionInInitializerError
org.eclipse.gef.examples.logicdesigner.CreateLogicPage1.getI nitialContents(C
reateLogicPage1.java:79)
and the next call
java.lang.NoClassDefFoundError
I pasted the full error message to the end of this posting. My configuration
other than GEF 2.0.1 Build I20030107 is EMF EMF 1.0.1 Build 20021127 0721VL
again because Omondo Eclipse UML requires it. The platform itself is
Version: 2.0.2 Build id: 200211071448, which I updated to the most current
versions with the Update function.
Thank you very much in advance for the help,
Martin
!SESSION Jan 29, 2003
19:17:53.120 ---------------------------------------------
java.version=1.4.1_01
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Command-line arguments: -dev bin -data
D:\Programme\Eclipse-SDK\eclipse\runtime-workspace\ -os win32 -ws
win32 -arch x86
!ENTRY org.eclipse.ui 4 4 Jan 29, 2003 19:17:53.120
!MESSAGE Unhandled exception caught in event loop.
!ENTRY org.eclipse.ui 4 0 Jan 29, 2003 19:17:53.160
!MESSAGE java.lang.ExceptionInInitializerError
!STACK 0
org.eclipse.ui.dialogs.WizardNewFileCreationPage.createNewFi le(WizardNewFile
CreationPage.java:175)
org.eclipse.gef.examples.logicdesigner.CreateLogicPage1.fini sh(CreateLogicPa
ge1.java:100)
org.eclipse.gef.examples.logicdesigner.LogicCreationWizard.p erformFinish(Log
icCreationWizard.java:30)
org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:577)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:312)
at org.eclipse.jface.dialogs.Dialog$1.widgetSelected(Dialog.jav a:407)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:87)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :77)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:827)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:1529)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1291)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:562 )
at org.eclipse.jface.window.Window.open(Window.java:542)
at org.eclipse.ui.actions.NewWizardAction.run(NewWizardAction.j ava:88)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:749 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(Action
ContributionItem.java:407)
org.eclipse.jface.action.ActionContributionItem.handleWidget Event(ActionCont
ributionItem.java:361)
org.eclipse.jface.action.ActionContributionItem.access$0(Act ionContributionI
tem.java:352)
org.eclipse.jface.action.ActionContributionItem$ActionListen er.handleEvent(A
ctionContributionItem.java:47)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1343)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1326)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.jav
a:831)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:432)
at EclipseRuntimeLauncher.main(EclipseRuntimeLauncher.java:24)
Caused by: java.lang.IllegalArgumentException: Argument cannot be null
at org.eclipse.swt.SWT.error(SWT.java:2105)
at org.eclipse.swt.SWT.error(SWT.java:2051)
at org.eclipse.swt.graphics.ImageLoader.load(ImageLoader.java:1 18)
at org.eclipse.swt.graphics.ImageData.<init>(ImageData.java:306)
at org.eclipse.swt.graphics.Image.<init>(Image.java:742)
org.eclipse.gef.examples.logicdesigner.model.LogicDiagram.<clinit >(LogicDiag
ram.java:24)
.... 29 more
!ENTRY org.eclipse.ui 4 4 Jan 29, 2003 19:50:10.216
!ENTRY org.eclipse.ui 4 0 Jan 29, 2003 19:50:10.536
!MESSAGE java.lang.NoClassDefFoundError
!STACK 0
ge1.java:100)
tem.java:352)
a:831)
Re: Problem with LogicDesigner Plugin Source Code in GEF I20030107 [message #59998 is a reply to message #59828] |
Wed, 29 January 2003 17:44   |
You have a PDE problem. Go into PDE preferences and click on "Not in
Workspace" button to remove external plugins that *ARE* in the workspace.
"Martin Dinkloh" <dinkloh@ipd.uni-karlsruhe.de> wrote in message
news:b1988j$auu$1@rogue.oti.com...
> Hello!
(www.omondo.com)
is
> also?
import
the
looked
> error message
> at
> and the next call
> at
configuration
0721VL
> Martin
> win32 -arch x86
> !STACK 0
> at
> at
> at
> ge1.java:100)
> at
> at
> at
> at
> at
> at
> at
> tem.java:352)
> at
> at
> a:831)
> at
> ram.java:24)
> ... 29 more
> !STACK 0
> at
> at
> at
> ge1.java:100)
> at
> at
> at
> at
> at
> at
> at
> tem.java:352)
> at
> at
> a:831)
Re: Problem with LogicDesigner Plugin Source Code in GEF I20030107 [message #60045 is a reply to message #59828] |
Thu, 30 January 2003 03:31   |
Originally posted by: m.spork.DELETE_THIS_SPAMBLOCKqut.edu.au
I'm using the same builds and had some problems as well but now have
it working.
Randy's post helped - I was then able to get to the point of trying to
create a new logic file - but it was not able to create the file.
On a hunch I thought it might be to do with missing resources - the
bitmaps for icons and pallette elements. So I extracted these from the
logic.jar file in
<eclipse_home>\plugins\org.eclipse.gef.examples.logic_2.0.1\runtime
and placed them in the appropriate folders on the projects src
directory.
This fixed the problem
On Wed, 29 Jan 2003 20:19:26 +0100, "Martin Dinkloh"
<dinkloh@ipd.uni-karlsruhe.de> wrote:
>Hello!
>also?
>error message
> at
>and the next call
> at
>Martin
>win32 -arch x86
>!STACK 0
>at
>at
>at
>ge1.java:100)
>at
>at
>at
>at
>at
>at
>tem.java:352)
>at
>at
>a:831)
>at
>ram.java:24)
>... 29 more
>!STACK 0
>at
>at
>at
>ge1.java:100)
>at
>at
>at
>at
>at
>at
>tem.java:352)
>at
>at
>a:831)
Re: Problem with LogicDesigner Plugin Source Code in GEF I20030107 [message #60430 is a reply to message #60045] |
Thu, 30 January 2003 16:22   |
Originally posted by: dinkloh.DELETE_THIS_SPAMBLOCKipd.uni-karlsruhe.de
Thank you very much for the help! The combination of your and Randy's
posting were the solution to my problem. First I excluded the LogicDesigner
plugin that came with the examples ZIP-file from the configuration menu for
the PDE and then I extracted the missing icons. Now it is working great!
"Murray Spork" <m.spork@DELETE_THIS_SPAMBLOCKqut.edu.au> schrieb im
Newsbeitrag news:vmmh3vg4ns7c0aaebamsglahb241ickqnt@4ax.com...
> it working.
> logic.jar file in
> directory.
> >Hello!
only
(www.omondo.com)
is
does
> >also?
to
import
plugin.xml,
the
the
looked
> >error message
> > at
C
> >and the next call
> > at
C
configuration
0721VL
current
> >Martin
> >win32 -arch x86
> >!STACK 0
> >at
C
> >at
e
> >at
a
> >ge1.java:100)
> >at
g
> >at
> >at
> >at
> >at
n
> >at
t
> >at
I
> >tem.java:352)
> >at
A
> >at
v
> >a:831)
> >at
g
> >ram.java:24)
> >... 29 more
> >!STACK 0
> >at
C
> >at
e
> >at
a
> >ge1.java:100)
> >at
g
> >at
> >at
> >at
> >at
n
> >at
t
> >at
I
> >tem.java:352)
> >at
A
> >at
v
> >a:831)
Re: Problem with LogicDesigner Plugin Source Code in GEF I20030107 [message #60835 is a reply to message #59828] |
Thu, 30 January 2003 16:37  |
The intended way to import out plugins into a workspace is to use the PDE's
Import external plugins. This hasn't been tested in a while, but if the
entire feature is present, including the source plugins, the PDE should
automatically do everything that you did manually.
> Hello!
(www.omondo.com)
is
> also?
import
the
looked
> error message
> at
> and the next call
> at
configuration
0721VL
> Martin
> win32 -arch x86
> !STACK 0
> at
> at
> at
> ge1.java:100)
> at
> at
> at
> at
> at
> at
> at
> tem.java:352)
> at
> at
> a:831)
> at
> ram.java:24)
> ... 29 more
> !STACK 0
> at
> at
> at
> ge1.java:100)
> at
> at
> at
> at
> at
> at
> at
> tem.java:352)
> at
> at
> a:831)
Current Time: Tue Jul 22 09:08:57 EDT 2025
Powered by FUDForum. Page generated in 0.11403 seconds
