Home » Language IDEs » C / C++ IDE (CDT) » Building Error with gcc...
Building Error with gcc... [message #59805] Sun, 26 January 2003 23:51 Go to next message
Originally posted by: inom1976.hotmail.com
I used Eclipse a bit and found it's very nice IDE.
However I faced a problem while building my simple "Hello, World!" program.
My error message was like the following:
**/usr/lib/gcc-lib/i686-pc-cygwin/3.2/../../../../i686-pc-cy gwin/bin/ld:
cannot find -luser32
collect2: ld returned 1 exit status**
I guess the main reason might be gcc which has wrong pathname between
cygwin and actual Windows.Thus gcc cannot find any required library and
files.
Does anyone know this problem? If yes, I really appreciate your help in
advance.
thanks!!!
Re: Building Error with gcc... [message #59831 is a reply to message #59805] Mon, 27 January 2003 04:53 Go to previous messageGo to next message
Originally posted by: f.frumento.sciro.com
I'm using cygwin with eclipse and other tools from mentor graphics...
they wotk fine
I think your problen id because You're using an absolute path... You
should specify only relative paths...
try to post your makefile
> files.
> advance.
> thanks!!!
Re: Building Error with gcc... [message #59855 is a reply to message #59805] Mon, 27 January 2003 13:37 Go to previous message
> files.
> advance.
-luser32 means that you want to link to user32.dll. Is this DLL
available on your system?
If so, tell gcc where by using the -L flag (i.e.
-L/my/user32/dll/file/is/here)
T
Previous Topic:Using environment variables
Next Topic:Memory in Debugger
Current Time: Sat Nov 22 02:03:28 EST 2025
Powered by FUDForum. Page generated in 0.02859 seconds
