Home » Archived » M2M (model-to-model transformation) » [QVT] Generic typed function
[QVT] Generic typed function [message #59803] Wed, 29 August 2007 05:40 Go to next message
Hi everyone,
I am writing a QVT oml transformation and I have come to a problem for
which I could not find a solution. I want to create a helper function
that returns elements of the model of a certain type. But instead of
creating one function for every type in the model, I tried to be smart
and parameterized the type:
modeltype UML uses
' http://www.eclipse.org/qvt/1.0.0/Operational/examples/simple uml';
mapping main(in model: UML::Model, out o: UML::Model) {
end {
o->ownedElements += object UML::Model {
ownedElements += model.ownedElements->getType(simpleuml::Package);
query UML::Packageable::getPackets(in type : PrimitiveType) :
Bag(UML::Packageable) {
self->select(oclIsTypeOf(type)) --filter type
->collect(oclAsType(simpleuml::Packageable)) --cast to supertype ;
This does not work, because as I understand it "oclIsTypeOf" is a
language construct and therefore the argument needs to be known at
compile time. So my question is: is there any other way to do this or do
you think this is bad-practice?
Thanks for your attantion,
Alfons
Re: [QVT] Generic typed function [message #59827 is a reply to message #59803] Wed, 29 August 2007 07:11 Go to previous message
You're right, you cannot use oclIsTypeOf in this way. The argument needs to
be a model type, as you have in oclAsType. I think you'll need a query for
each type, or a query that has a series of conditionals. Or, skip the query
and just use select/collect for the type where you need it.
Best,
Rich
On 8/29/07 5:40 AM, in article fb3eud$tge$1@build.eclipse.org, "Alfons
Laarman" <alfons.laarman@obeo.fr> wrote:
> Hi everyone,
> modeltype UML uses
> end {
> Alfons
Previous Topic:Stereotype property with defined type
Next Topic:UserInteraction in Transformationprocess
Current Time: Thu Jul 17 19:52:49 EDT 2025
Powered by FUDForum. Page generated in 0.05220 seconds
