Home » Modeling » OCL » Forward Declaration
Forward Declaration [message #59791] Tue, 29 July 2008 09:29 Go to next message
I have the following model:
Activity
While
Flow
Sequence
AtomicActivity
Now I defined a operation maxCount for Activity, which calls the appropriate
operation for the Subtypes. But the SubElements While, Flow and Sequence can
contain Elements of Type Activity. So I should be able to call the maxCount
for Activity again. But all I get is:
"Cannot find operation (maxCount) for the type (Activity))"
The operation requires additionally a parameter, so I can't use derived
Attributes.
Any Ideas how I could solve my Problem? Is there the possibility to make
forward declarations?
Thomas
Re: Forward Declaration [message #59817 is a reply to message #59791] Tue, 29 July 2008 13:20 Go to previous messageGo to next message
Originally posted by: cdamus.zeligsoft.com
Hi, Thomas,
Which version of MDT OCL are you using? 1.2 (Ganymede)?
This sounds like this bug: https://bugs.eclipse.org/187679
If your operation definition is referencing itself, then you should
already be OK. Otherwise, if you define the Activity::maxCount
operation before the one that references it (i.e., earlier in the *.ocl
file), then you should also be OK.
HTH,
Christian
Thomas Kurpick wrote:
> Activity
> While
> Flow
> Sequence
> AtomicActivity
> Attributes.
> Thomas
Re: Forward Declaration [message #59890 is a reply to message #59817] Wed, 30 July 2008 09:25 Go to previous message
I'm using OCL 2.0 Extender SDK 1.1.2 (Europa)
And it's exactly this bug. I fixed my problem by putting all code into one
operation.
Ugly but it works.
Thomas
Previous Topic:OCL Expression
Next Topic:[Announce] MDT OCL 1.2.1 M200807301501 is available
Current Time: Wed Oct 29 02:30:45 EDT 2025
Powered by FUDForum. Page generated in 0.03662 seconds
