| Forward Declaration [message #59791] | Tue, 29 July 2008 09:29  |  |
| Eclipse User  |  |  |  |  | Hi,
 I have the following model:
 Activity
 While
 Flow
 Sequence
 AtomicActivity
 Now I defined a operation maxCount for Activity, which calls the appropriate
 operation for the Subtypes. But the SubElements While, Flow and Sequence can
 contain Elements of Type Activity. So I should be able to call the maxCount
 for Activity again. But all I get is:
 "Cannot find operation (maxCount) for the type (Activity))"
 The operation requires additionally a parameter, so I can't use derived
 Attributes.
 Any Ideas how I could solve my Problem? Is there the possibility to make
 forward declarations?
 Thomas
| Re: Forward Declaration [message #59817 is a reply to message #59791] | Tue, 29 July 2008 13:20   |  |
| Eclipse User  |  |  |  |  | Originally posted by: cdamus.zeligsoft.com
 Hi, Thomas,
 Which version of MDT OCL are you using? 1.2 (Ganymede)?
 This sounds like this bug:  https://bugs.eclipse.org/187679
 If your operation definition is referencing itself, then you should
 already be OK.  Otherwise, if you define the Activity::maxCount
 operation before the one that references it (i.e., earlier in the *.ocl
 file), then you should also be OK.
 HTH,
 Christian
 Thomas Kurpick wrote:
 > Activity
 >     While
 >     Flow
 >     Sequence
 >     AtomicActivity
 > Attributes.
 > Thomas
FUDForum. Page generated in 0.78078 seconds
