Home » Modeling » GMF (Graphical Modeling Framework) » where in the code do you specify which elements can be created when hovering over the document?
where in the code do you specify which elements can be created when hovering over the document? [message #59784] |
Thu, 05 October 2006 15:24  |
Originally posted by: liam.morley.baesystems.com
Using the help guide, I've been able to figure out how to add tools to the
palette. I haven't been able to figure out, however, how to change the
behavior for when you hover over the document. Right now, one of my model
objects shows up twice in the menu- I see "Add Node", "Add Link", and then
"Add Node" again. I don't want to see "Add Link" at all (it's a connection),
and I only want to see "Add Node" once. I started with the gmfgen file, but
I need to work with and make changes directly to the generated code, so I'm
trying to figure out how to modify the code/plugin.xml directly.
Thanks!
Liam Morley
Re: where in the code do you specify which elements can be created when hovering over the document? [message #59836 is a reply to message #59784] |
Thu, 05 October 2006 16:10   |
Check subclasses of ModelingAssistantProvider
Artem
"Liam Morley" <liam.morley@baesystems.com> wrote in message
news:eg3m5e$olm$1@utils.eclipse.org...
> connection), and I only want to see "Add Node" once. I started with the
> gmfgen file, but I need to work with and make changes directly to the
> generated code, so I'm trying to figure out how to modify the
> Thanks!
> Liam Morley
Re: where in the code do you specify which elements can be created when hovering over the document? [message #60031 is a reply to message #59836] |
Fri, 06 October 2006 07:42   |
Liam,
The default behavior of the PopupBarEditPolicy installed on the diagram
will get the popupbar items based on the items on the last active drawer
in the palette. Put a breakpoint in
DiagramPopupBarEditPolicy.fillPopupBarDescriptors() to understand what
is going on.
The default behavior of the PopupBarEditPolicy installed on other
editparts, is to get the list of types for the popupbar from the
Modeling Assistant Service. Check out the method getTypesForPopupBar().
- Cherie
> Artem
>> Thanks!
>> Liam Morley
Re: where in the code do you specify which elements can be created when hovering over the document? [message #60387 is a reply to message #60031] |
Fri, 06 October 2006 14:50  |
Thanks to the both of you, that's a big help!
Liam
"Cherie Revells" <crevells@ca.ibm.com> wrote in message
news:eg5fl0$i4i$1@utils.eclipse.org...
> Liam,
> DiagramPopupBarEditPolicy.fillPopupBarDescriptors() to understand what is
> going on.
> editparts, is to get the list of types for the popupbar from the Modeling
> - Cherie
>> Artem
>>> the palette. I haven't been able to figure out, however, how to change
>>> the behavior for when you hover over the document. Right now, one of my
>>> model objects shows up twice in the menu- I see "Add Node", "Add Link",
>>> and then "Add Node" again. I don't want to see "Add Link" at all (it's a
>>> Thanks!
>>> Liam Morley
Current Time: Fri Jul 18 22:42:05 EDT 2025
Powered by FUDForum. Page generated in 0.02718 seconds
