Home » Language IDEs » C / C++ IDE (CDT) » Outline problem with anonymous structs
Outline problem with anonymous structs [message #59780] Fri, 24 January 2003 10:28 Go to next message
Originally posted by: f.frumento.sciro.com
Hi! I've used a bit CDT it's very nice but in my project i've some
anonymous typedefs.. and the outline stop to show after the first...
here's an example...
typedef struct {
int a;
int b;
int c;
}a_struct;
typedef struct {
int e;
int f;
int g;
}b_struct;
typedef struct {
int h;
int i;
int l;
}c_struct;
another example
typedef struct a_s {
int a;
int b;
int c;
}a_struct;
typedef struct {
int e;
int f;
int g;
}b_struct;
typedef struct {
int h;
int i;
int l;
}c_struct;
in the second example the outline show the a_s struct and the b_struct
as anonymous... but not the c_struct type...
thanks and regards
Fabio
Re: Outline problem with anonymous structs [message #61021 is a reply to message #59780] Mon, 03 February 2003 19:42 Go to previous messageGo to next message
Yes, The parser is failing. I got no solution for you
at this point. The solution of course is: we need a
better parser .. and we are working on it, can not
even promise it for the next release 8-(.
Thanks for the test case.
> typedef struct {
> int a;
> int b;
> int c;
> }a_struct;
> typedef struct {
> int e;
> int f;
> int g;
> }b_struct;
> typedef struct {
> int h;
> int i;
> int l;
> }c_struct;
> another example
> int a;
> int b;
> int c;
> }a_struct;
> typedef struct {
> int e;
> int f;
> int g;
> }b_struct;
> typedef struct {
> int h;
> int i;
> int l;
> }c_struct;
> thanks and regards
> Fabio
Re: Outline problem with anonymous structs [message #61552 is a reply to message #61021] Fri, 07 February 2003 08:28 Go to previous messageGo to next message
ok thanks... just to know if I was wrong :-)
where to check the parser code ? I would like to sustain the project...
Re: Outline problem with anonymous structs [message #61697 is a reply to message #61552] Fri, 07 February 2003 16:17 Go to previous messageGo to next message
It is in the cvs branch on dev.eclipse.org:/home/tools,
plugin org.eclipse.cdt.core (new_parser).
IBM/Rational is leading the project.
Re: Outline problem with anonymous structs [message #62130 is a reply to message #61697] Thu, 13 February 2003 05:29 Go to previous message
Previous Topic:starters help conserning import of java files
Next Topic:Dynamic universal Make file
Current Time: Fri Oct 31 01:46:44 EDT 2025
Powered by FUDForum. Page generated in 0.03110 seconds
