Home » Newcomers » Newcomers » message.properties out of sync
message.properties out of sync [message #59756] Fri, 29 April 2005 14:38 Go to next message
Originally posted by: thomas.cormode.teckcominco.com
I am using Eclipse to write a Java project. Last week I used the
'Externalize Strings' option. This week when I go to use this option,
Eclipse informs me that "Resource './xxx/messages.properties' is out of
sync with the file system." I have replaced the Externalized Strings in
the Java code and have deleted the messages.properties file. The hope was
that Eclipse would recreate it when I tried to use the 'Externalize
Strings' again. Unfortunately, this did not work. What should I do to be
able to use 'Externalize Strings' again?
T. Cormode
Re: message.properties out of sync [message #59860 is a reply to message #59756] Fri, 29 April 2005 16:40 Go to previous message
Refresh (hit F5) the hierarchy under your Java project to pickup the file
system delete.
HTH
Darins
"Thomas Cormode" <thomas.cormode@teckcominco.com> wrote in message
news:458f747670668fccedd85751b85735b8$1@www.eclipse.org...
> T. Cormode
Previous Topic:Debug mode, exception with breakpoints enabled
Next Topic:Why can't eclipse create a regular project
Current Time: Tue Dec 02 11:57:06 EST 2025
Powered by FUDForum. Page generated in 0.09289 seconds
