Home » Modeling » GMF (Graphical Modeling Framework) » does the notation model extend the ecore model?
does the notation model extend the ecore model? [message #59711] Thu, 05 October 2006 14:27 Go to next message
Why does the notation model contain elements that are subtypes of
elements in the ecore model, for example "View" is a subtype of
"EModelElement", "View" is declared in the notation package, while
"EModelElement" is coming from the ecore model.
In my understanding the ecore model is the model of all models, and
extending it is like merging two layers...?
I understand that it is perfectly legal to do this, but i thought one
better shouldnt touch the ecore model. This really confuses me.
Thanks for any comments,
Felix
Re: does the notation model extend the ecore model? [message #59737 is a reply to message #59711] Thu, 05 October 2006 14:38 Go to previous messageGo to next message
Originally posted by: vcciubot.uwaterloo.ca
Take a look at:
http://dev.eclipse.org/viewcvs/indextools.cgi/*checkout*/org .eclipse.emf/doc/org.eclipse.emf.doc/references/overview/EMF .html
There's a lot of help provided on the emf newsgroup.
vlad
On Thu, 05 Oct 2006 20:27:38 +0200, Felix Dorner wrote:
> Felix
Re: does the notation model extend the ecore model? [message #60007 is a reply to message #59737] Fri, 06 October 2006 07:45 Go to previous messageGo to next message
Hello Vlad,
> Take a look at:
> mf/doc/org.eclipse.emf.doc/references/overview/EMF.html
Yes, but the question “why is it necessary to extend EModelElement by
View?” is interesting for me as well. Are there any reasons to do it? (probably
yes…)
I suppose, somebody from the runtime team can comment it.
Alex Shatalin
Re: does the notation model extend the ecore model? [message #60174 is a reply to message #60007] Fri, 06 October 2006 09:23 Go to previous messageGo to next message
Alex,
I always tell people, don't extend the Ecore model, but which I mean,
don't extend any EClass from EModelElement downward. It's not that this
is inherently evil, it's just that this introduces a dependency on
EModelElementImpl and we do not promise to keep binary compatibility for
our Impls (and in fact cannot due that adding features changes the
feature IDs for derived classes). Of course many people ignore this
advice, often because they made their decision before they were aware of
the advice. The usual reason given for ignoring the advice is that
EModelElement has those lovely EAnnotations that appear to be so highly
reusable. But they can be reused by defining a containment reference of
type EAnnotation on your own model's classes without extending
EModelElement and hence without introducing binary compatibilities
concerns, so it's not a very good reason for ignoring the advice. ;-)
Alex Shatalin wrote:
> Hello Vlad,
>> Take a look at:
> by View?” is interesting for me as well. Are there any reasons to do
> it? (probably yes…) I suppose, somebody from the runtime team can
> comment it.
> Alex Shatalin
Re: does the notation model extend the ecore model? [message #60246 is a reply to message #60174] Fri, 06 October 2006 10:51 Go to previous messageGo to next message
Hello Ed,
I realize the situation exactly as you described. ;-) I’m not afraid of dependency
from ECore, but I’d like to know the reason for it – just to have a better
overview of the current situation.
Alex Shatalin
Re: does the notation model extend the ecore model? [message #60269 is a reply to message #60174] Fri, 06 October 2006 10:55 Go to previous messageGo to next message
Hi, Ed,
To play a little "devil's advocate": the problem with defining one's own
annotation feature is that EModelElement can be viewed as defining a common
"I am an annotatable element" type that can be understood by code that uses
Ecore reflection. Any code that wants to deal in a generic fashion with
annotations on annotatable elements would, otherwise, have to search for a
containment reference of type EAnnotation (probably preferring a reference
named 'eAnnotations', if there is one). It would be difficult to ensure
that the feature actually is intended for general-purpose annotations
(maybe a standard annotation on the annotation feature, itself, from the
ExtendedMetaData would help?).
Christian
Ed Merks wrote:
> Alex,
<snip>
Re: does the notation model extend the ecore model? [message #60316 is a reply to message #60269] Fri, 06 October 2006 11:05 Go to previous messageGo to next message
Hello Christian,
I thought that Style could (should) be used instead of Annotation in Notation
model..
Alex Shatalin
Re: does the notation model extend the ecore model? [message #60340 is a reply to message #60316] Fri, 06 October 2006 11:27 Go to previous messageGo to next message
Hi, Alex,
Yes, that is the endorsed way to add custom properties to notation shapes.
I was just remarking on the larger question of generic annotations a la
<xsd:annotation>.
Christian
> Hello Christian,
> Notation model..
> Alex Shatalin
Re: does the notation model extend the ecore model? [message #60364 is a reply to message #60269] Fri, 06 October 2006 11:56 Go to previous message
--------------040906090605030605070303
Christian,
This is not particularly convincing. ;-) A few EcoreUtil methods would
be reusable, but that's about it. EModelElement was never intended as a
generic Annotatable API. It was intended to be the root object of Ecore
model's hierarchy. Also, generic code could act directly on the list
returned by getEAnntotation() or whatever the method is called in
another model. I could imagine defining an Annotatable API and mixing
that into ModelElement as a better approach. But this is all water
under the bridge and since there is a coordinated effort to release all
our plugins at once, the binary compatibility issues are of minimal concern.
Christian W. Damus wrote:
> Hi, Ed,
> Cheers,
> Christian
> Ed Merks wrote:
>> Alex,
> <snip>
<html>
<head>
</head>
Christian,<br>
<br>
This is not particularly convincing. ;-)&nbsp;&nbsp; A few EcoreUtil methods
would be reusable, but that's about it.&nbsp; EModelElement was never
intended as a generic Annotatable API.&nbsp; It was intended to be the root
object of Ecore model's hierarchy.&nbsp; Also, generic code could act
directly on the list returned by getEAnntotation() or whatever the
method is called in another model.&nbsp; I could imagine defining an
Annotatable API and mixing that into ModelElement as a better
approach.&nbsp; But this is all water under the bridge and since there is a
coordinated effort to release all our plugins at once, the binary
compatibility issues are of minimal concern.<br>
<br>
<br>
<blockquote cite="mideg5qoc$aqh$1@utils.eclipse.org" type="cite">
<pre wrap="">Hi, Ed,
Christian
Ed Merks wrote:
</pre>
<blockquote type="cite">
<pre wrap="">Alex,
</pre>
</blockquote>
<pre wrap=""><!---->
&lt;snip&gt;
</pre>
</blockquote>
<br>
</body>
</html>
--------------040906090605030605070303--
Previous Topic:Validating notation.genmodel
Next Topic:where in the code do you specify which elements can be created when hovering over the document?
Current Time: Sun Jul 27 07:20:11 EDT 2025
Powered by FUDForum. Page generated in 0.04742 seconds
