Home » Language IDEs » PHP Development Tools (PDT) » error, Duplicate tag (HTML).
error, Duplicate tag (HTML). [message #59699] Sun, 28 October 2007 00:01 Go to next message
Originally posted by: samw3office.gmail.com
Hello All,
I'm getting a "Duplicate tag (HTML)." error on the second <DOCTYPE> tag
in my script as well as a "Duplicate tag (html)." warning on the second
<html> tag.
Is PDT doing this? and if so, can I set it somehow to not do it? (like
ignore or something?)
Thanks!
Sam Washburn
The script I'm using boils down to this...
if($something) {
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN"
"http://www.w3.org/TR/html4/strict.dtd">
<html>
<body>
DISPLAY ONE FORM
</body>
</html>
} else {
<html>
<body>
DISPLAY DIFFERENT FORM
</body>
</html>
Re: error, Duplicate tag (HTML). [message #59723 is a reply to message #59699] Sun, 28 October 2007 11:24 Go to previous messageGo to next message
Originally posted by: ganoro.gmail.com
The HTMLValidator generates this error message. Semnatically your snippet
is valid though consider using this equivalent snippet.
<html>
<body>
if ($something) {
DISPLAY ONE FORM
} else {
</body>
</html>
Re: error, Duplicate tag (HTML). [message #59770 is a reply to message #59723] Sun, 28 October 2007 12:31 Go to previous messageGo to next message
Thanks but..
Is the HTMLValidator a part of PDT or just eclipse? It would be nice
if there was a way to selectively choose which errors the validator
calls an error.
The code snippet you offered would solve the problem, however, I my
other code logic makes it a bit difficult.. kind of like this:
if($_REQUEST['form_clicked']){
// Process form here..
// Then redirect to another page.
} elseif($something) {
<html><body>DISPLAY ONE FORM</body></html>
} else {
<html><body>DISPLAY DIFFERENT FORM</body></html>
> snippet is valid though consider using this equivalent snippet.
> <html>
> <body>
> if ($something) {
> DISPLAY ONE FORM
> } else {
> </body>
> </html>
Re: error, Duplicate tag (HTML). [message #59794 is a reply to message #59770] Mon, 29 October 2007 02:45 Go to previous message
It is not a bug of the validator, since the validator can't understand
(semantically) the meaning of the program, it is an undecidable question.
Again, you should state the doctype only once in your document, for
example you can write a function that writes the doctype and then you call
it from the two branches that need to use it.
Previous Topic:Feature question for depoying
Next Topic:[Article] Extending the PDT project
Current Time: Sat Nov 08 19:24:09 EST 2025
Powered by FUDForum. Page generated in 0.03099 seconds
