| error, Duplicate tag (HTML). [message #59699] |
Sun, 28 October 2007 00:01  |
Originally posted by: samw3office.gmail.com
Hello All,
I'm getting a "Duplicate tag (HTML)." error on the second <DOCTYPE> tag
in my script as well as a "Duplicate tag (html)." warning on the second
<html> tag.
Is PDT doing this? and if so, can I set it somehow to not do it? (like
ignore or something?)
Thanks!
Sam Washburn
The script I'm using boils down to this...
if($something) {
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN"
"http://www.w3.org/TR/html4/strict.dtd">
<html>
<body>
DISPLAY ONE FORM
</body>
</html>
} else {
<html>
<body>
DISPLAY DIFFERENT FORM
</body>
</html>
| Re: error, Duplicate tag (HTML). [message #59794 is a reply to message #59770] |
Mon, 29 October 2007 02:45  |
It is not a bug of the validator, since the validator can't understand
(semantically) the meaning of the program, it is an undecidable question.
Again, you should state the doctype only once in your document, for
example you can write a function that writes the doctype and then you call
it from the two branches that need to use it.
FUDForum. Page generated in 0.08259 seconds
