Home » Eclipse Projects » Equinox » Is there a simple OSGi Bundle in Eclipse tree?
Is there a simple OSGi Bundle in Eclipse tree? [message #59656] Thu, 02 February 2006 23:13 Go to next message
Is there a simple OSGi Bundle in Eclipse tree that I can follow to
create my own? I am totally lost without any concrete docs/examples :-(
TIA,
Rahul
Re: Is there a simple OSGi Bundle in Eclipse tree? [message #61016 is a reply to message #59656] Thu, 09 February 2006 16:32 Go to previous messageGo to next message
Originally posted by: jeff_nospam_mcaffer.ca.ibm.com
You can make a simple bundle using the "new plugin project" wizard. Follow
the steps and be sure to select the "an OSGi framework" radio button in the
Target Platform section. then on the third page you have an option to
choose a template. The Hello OSGi bundle template creates a bundle with a
simple activator etc.
Does that capture what you are after?
Jeff
"Rahul" <rahul.thakur@clear.net.nz> wrote in message
news:drula6$bqj$1@utils.eclipse.org...
> TIA,
> Rahul
Re: Is there a simple OSGi Bundle in Eclipse tree? [message #61228 is a reply to message #61016] Fri, 10 February 2006 13:09 Go to previous message
Originally posted by: morova.bol.com.br
I would also point you to
http://oscar-osgi.sourceforge.net/tutorial/index.html
and
http://www.knopflerfish.org/osgi_service_tutorial.html
Gustavo
> Jeff
>> TIA,
>> Rahul
Previous Topic:correct dependencies for Event Admin
Next Topic:Eclipse-PatchFragment ?
Current Time: Mon Jul 21 21:51:41 EDT 2025
Powered by FUDForum. Page generated in 0.46069 seconds
