Home » Archived » Test and Performance Tools Platform (TPTP) » No. of Users in TPTP
No. of Users in TPTP [message #59626] Tue, 21 March 2006 15:01 Go to next message
Originally posted by: nospam.nospam.com
Hi..All,
While executing the test recorded from HTTP URL, I increased the no. of
users from 1 to 50. I see lot of difference between the run time from 1 user
to 50 users. The test finishes only after an hour or so. My understanding
was that the 50 users will be running simultaneously . Am I right?
Secondly, I can see that I can scale the no. of users, how do I set the time
for the test to run & finish?
P
Re: No. of Users in TPTP [message #60238 is a reply to message #59626] Mon, 27 March 2006 07:44 Go to previous message
Hi Praaveen,
This appears to be a defect since each simulated user should run in a
separate thread. Please open a bugzilla at
https://bugs.eclipse.org/bugs/enter_bug.cgi?classification=T PTP.
Unfortunately, the test author or tester can configure an execution time
or the duration of the test. However, to configure the execution time, have
a look at the TPTP automatable service framework (see Help >> Help
Contents). This is an automatable test execution service is provided for
launching tests programmatically via scripts (e.g. shell and ANT) and
external applications (e.g. Java).
Paul
"Praveen" <nospam@nospam.com> wrote in message
news:dvpm3k$d7d$1@utils.eclipse.org...
> Hi..All,
user
time
> P
Previous Topic:Can .NET apps be tested with TPTP? <eom>
Next Topic:Still Having Problems, Please help
Current Time: Mon Jul 14 21:28:17 EDT 2025
Powered by FUDForum. Page generated in 0.05985 seconds
