Home » Modeling » TMF (Xtext) » Generation oddity with imported grammar
Generation oddity with imported grammar [message #59618] Thu, 16 July 2009 15:40 Go to next message
I get a strange generation error with already generated packages from
imported grammar duplicated in dependent grammar project src-gen.
context :
grammar A with Terminals
TopA :
(xyzs+=XYZ)+
XYZ :
'xyz' name=ID ';'
grammar B with A
import "http://www.sf.net/ABC"
// ABC package URI as declared in A/plugin.xml resolve XYZ right !
TopB :
(imports+=IMPORT)+
(links+=LINK)+
IMPORT:
'import' uri=STRING ';'
LINK :
' link' name=ID 'to' refXYZ=[XYZ] ';' // from A
question :
*) http:// protocol URI for imported package pb ?
strange behavior : already generated packages from imported grammar A are
duplicated in dependent grammar B project src-gen directory.
When looking at B.genmodel something say 'http://sourceforge.net/ABC' not
found.
Pb is : I declared "http://www.sf.net/ABC" and tried to import accordingly
Should generated_package extension IDs like 'http://...' should be avoided
Is it a bug ?
Is it working as it should ?
regards,
Re: Generation oddity with imported grammar [message #59647 is a reply to message #59618] Thu, 16 July 2009 16:20 Go to previous messageGo to next message
Hi Lucas,
did set the reference to the existing genModels in your
EcoreGeneratorFragment?
Please have a look at the docs for details about it (or search this
newsgroup for "genModels".
http://www.eclipse.org/Xtext/documentation/0_7_0/xtext.html (search for
genModels
Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 16.07.2009 21:40 Uhr, schrieb lucas bigeardel:
> context :
> TopA :
> (xyzs+=XYZ)+
> XYZ :
> 'xyz' name=ID ';'
> grammar B with A
> import "http://www.sf.net/ABC" // ABC package URI as declared in
> TopB :
> (imports+=IMPORT)+
> (links+=LINK)+
> IMPORT:
> LINK :
> question :
> are duplicated in dependent grammar B project src-gen directory.
> not found.
> accordingly ... !
> avoided ?
> Is it a bug ?
> regards,
Re: Generation oddity with imported grammar [message #59765 is a reply to message #59647] Thu, 16 July 2009 18:20 Go to previous messageGo to next message
Sebastian Zarnekow wrote:
> Hi Lucas,
> genModels
in this doc 'platform:' should be read 'platform:/resource'
just realized after reading the excellent article from M. Paternostro :
http://lmap.blogspot.com/2008/03/platform-scheme-uri.html
> Sebastian
Re: Generation oddity with imported grammar [message #59813 is a reply to message #59765] Thu, 16 July 2009 19:45 Go to previous messageGo to next message
>> Hi Lucas,
>> genModels
Solution working for me :
Adding a package import in B.xtext
import "http://www.sf.net/A/XYZ"
Adding a new bean in GenerateDSL.mwe :
<bean class="org.eclipse.emf.mwe.utils.StandaloneSetup"
platformUri="${runtimeProject}/../project/src-gen">
<registerGeneratedEPackage value="net.sf.A.XYZPackage"/>
</bean>
And modifying EcoreGeneratorFragment fragment :
<fragment
class="org.eclipse.xtext.generator.ecore.EcoreGeneratorFragment "
genModels=" platform:/resource/project/src-gen/net/sf/xqz/engine/script/ Orchestror.genmodel "
Et voila !
>> Regards,
>> Sebastian
Re: Generation oddity with imported grammar [message #59909 is a reply to message #59765] Fri, 17 July 2009 04:54 Go to previous message
Hi Lucas,
I've searched the docs for platform: but could not spot the mistake. Can
you give me a hint as I'ld like to fix it.
Sebastian
Am 17.07.2009 0:20 Uhr, schrieb lucas bigeardel:
>> Hi Lucas,
>> for genModels
>> Regards,
>> Sebastian
Previous Topic:Crossreference & lazy loading pb ?
Next Topic:[Xtext] Update highlighting after document change
Current Time: Sat Jul 26 07:36:42 EDT 2025
Powered by FUDForum. Page generated in 0.04548 seconds
