Home » Language IDEs » AspectJ » AJDT and workspace JRE
AJDT and workspace JRE [message #59486] Fri, 16 December 2005 13:21 Go to next message
I have a problem with the combination of Eclipse 3.1, JRE 1.5.0 and AJDT
20051111104438.
The problem is at the runtime of the deployment generated by an ANT script
running inside Eclipse with the JRE of the workspace (not when I edit or
compile aspects).
In one of the classes, I have a statement like
BigDecimal var = new BigDecimal(123);
I get an exception for this statement at runtime,
java.lang.NoSuchMethodError: java.math.BigDecimal.(I)V
In the ANT script, I have set the source and target compability to 1.4.
I have this problem only if I start Eclipse with JRE 1.5.0.
If I start Eclipse with JRE 1.4.2, the generated deployment works just
fine. I do not have the problem with the BigDecimal.
I use AspectJ150_M2 in the ANT script. Is this AspectJ build too old for
JRE 1.5.0 ?
Harry
Re: AJDT and workspace JRE [message #59540 is a reply to message #59486] Fri, 16 December 2005 13:45 Go to previous messageGo to next message
> JRE 1.5.0 ?
Positively ancient!! There have been a LOT of bug fixes relating to Java
5 features since M2. AspectJ 5 RC1 is now out and it would be well-worth
updating.
Let me know if the problem still persists after that...
Thanks, Adrian.
harry sheng wrote:
> 20051111104438.
> script running inside Eclipse with the JRE of the workspace (not when I
> edit or compile aspects).
> JRE 1.5.0 ?
> Harry
Re: AJDT and workspace JRE [message #59608 is a reply to message #59540] Fri, 16 December 2005 15:58 Go to previous messageGo to next message
Hi Adrian,
I upgraded AJDT to 20051214130641 (well, I do not think the problem is
related to AJDT), downloaded AspectJ 150 RC1, updated my ANT script to use
the latest AspectJ RC1, upgraded the aspectjrt.jar for my deployment.
There's no change to the problem. OK if JRE 1.4.2 is used, SAME exception
araised if JRE 1.5.0 is used.
Harry
> > JRE 1.5.0 ?
> updating.
> Thanks, Adrian.
> harry sheng wrote:
>> 20051111104438.
>> JRE 1.5.0 ?
>> Harry
Re: AJDT and workspace JRE [message #59632 is a reply to message #59608] Sat, 17 December 2005 02:48 Go to previous messageGo to next message
Ok, that's definitely something we need to investigate then. I need to
look at the definition of the BigDecimal class in both runtime libraries
(are you using a Sun JDK?) and do some tests. It could be an
environmental issue (different compile-time and runtime libraries), or
it could potentially be a bug. Please could you raise a bugzilla report
so that we can track it?
Thanks, Adrian.
Harry Sheng wrote:
> Hi Adrian,
> use the latest AspectJ RC1, upgraded the aspectjrt.jar for my deployment.
> exception araised if JRE 1.5.0 is used.
> Harry
>> old for
>> > JRE 1.5.0 ?
>> Java 5 features since M2. AspectJ 5 RC1 is now out and it would be
>> well-worth updating.
>> Thanks, Adrian.
>> harry sheng wrote:
>>> Hi,
>>> AJDT 20051111104438.
>>> I edit or compile aspects).
>>> just fine. I do not have the problem with the BigDecimal.
>>> for JRE 1.5.0 ?
>>> Harry
Re: AJDT and workspace JRE [message #59652 is a reply to message #59632] Sat, 17 December 2005 16:08 Go to previous messageGo to next message
My deployment environments are SunOne WebServer6.1 and Tomcat 5 on Win2K,
Sun JDK 1.4.2.
I used to use Sun Java compiler when I was using Eclipse 3.0. After
upgraded to Eclipse 3.1, I have to add serialVersionUID to every class I
need to serialize and transfer instances between clients and servers,
other wise I won't be able debug client code in Eclipse. So new I use
eclipse compiler to create the deployment, but the deployment environments
use Sun JDK.
> Thanks, Adrian.
> Harry Sheng wrote:
>> Hi Adrian,
>> Thanks,
>> Harry
Re: AJDT and workspace JRE [message #59676 is a reply to message #59652] Sun, 18 December 2005 12:45 Go to previous message
I looked into this today... here's a copy of the comment on the bug
report for those just following on the forum:
The constructor BigDecimal(int) was only introduced in 1.5 (does not
exist in 1.4).
When you compile your code under Eclipse with a 1.5 JDK, it creates a
call to the BigDecimal(int) constructor (best match in the class). When
you then run it under 1.4, that method can't be found.
When you compile you code under Eclipse with a 1.4 JDK, the constructor
call is converted to BigDecimal(double) (the only matching constructor
under 1.4), which of course can be found by your 1.4 runtime.
So... if you want to run Eclipse under JDK 1.5, what you need to do is
edit the properties of your project and in the Java Build Path, make
sure you are using the 1.4 rt.jar, and not the 1.5 one. (Just setting
compiler source and target to 1.4 does *not* change the runtime library
- a trap I've fallen into myself on several occassions). Changing your
constructor call to "new BigDecimal((double)1234)" will also work, but
is nowhere near as good overall as using the right rt.jar to build!
Regards, Adrian.
> Win2K, Sun JDK 1.4.2.
> environments use Sun JDK.
>> libraries (are you using a Sun JDK?) and do some tests. It could be an
>> report so that we can track it?
>> Thanks, Adrian.
>> Harry Sheng wrote:
>>> Hi Adrian,
>>> is related to AJDT), downloaded AspectJ 150 RC1, updated my ANT
>>> script to use the latest AspectJ RC1, upgraded the aspectjrt.jar for
>>> my deployment.
>>> Thanks,
>>> Harry
Re: AJDT and workspace JRE [message #591336 is a reply to message #59486] Fri, 16 December 2005 13:45 Go to previous message
> JRE 1.5.0 ?
updating.
Thanks, Adrian.
harry sheng wrote:
> 20051111104438.
> JRE 1.5.0 ?
> Harry
Re: AJDT and workspace JRE [message #591367 is a reply to message #59540] Fri, 16 December 2005 15:58 Go to previous message
Hi Adrian,
Harry
> > JRE 1.5.0 ?
> updating.
> Thanks, Adrian.
> harry sheng wrote:
>> 20051111104438.
>> JRE 1.5.0 ?
>> Harry
Re: AJDT and workspace JRE [message #591373 is a reply to message #59608] Sat, 17 December 2005 02:48 Go to previous message
Thanks, Adrian.
Harry Sheng wrote:
> Hi Adrian,
> Harry
>> old for
>> > JRE 1.5.0 ?
>> Thanks, Adrian.
>> harry sheng wrote:
>>> Hi,
>>> for JRE 1.5.0 ?
>>> Harry
Re: AJDT and workspace JRE [message #591384 is a reply to message #59632] Sat, 17 December 2005 16:08 Go to previous message
Sun JDK 1.4.2.
use Sun JDK.
> Thanks, Adrian.
> Harry Sheng wrote:
>> Hi Adrian,
>> Thanks,
>> Harry
Re: AJDT and workspace JRE [message #591395 is a reply to message #59652] Sun, 18 December 2005 12:45 Go to previous message
exist in 1.4).
Regards, Adrian.
>> Thanks, Adrian.
>> Harry Sheng wrote:
>>> Hi Adrian,
>>> my deployment.
>>> Thanks,
>>> Harry
Previous Topic:Erroneous error marking in editor for introduced methods
Next Topic:Eclipse 3.2M4
Current Time: Fri Nov 07 19:14:10 EST 2025
Powered by FUDForum. Page generated in 0.04500 seconds
