Home » Eclipse Projects » Nebula » [Grid] DefaultCellRenderer and wordwrap
[Grid] DefaultCellRenderer and wordwrap [message #59466] Thu, 25 September 2008 12:13 Go to next message
I'd like to use Grid/GridViewer to create a table with variable line
heights, with the lines' heights adjusting to show the whole contents of
the line.
When using
gridviewer.setAutoPreferredHeight(true) combined with
column.setWordWrap(true) for each column
I end up with each row being very much too high. I'm using the smallfonts
option running from macosx. Is this a bug? I've looked at the source code:
why doesn't it just call getBounds on the TextLayout object used for
computing row height?
Also, the line height doesn't automatically increase when I make a column
narrower.
Help?
Greg
Re: [Grid] DefaultCellRenderer and wordwrap [message #59561 is a reply to message #59466] Sat, 27 September 2008 16:26 Go to previous message
The answer to my problem is that I am an idiot. Some weird "legacy" code I
was running changes the width *after* the row height is calculated.
> When using
> narrower.
> Help?
> Regards
> Greg
Re: [Grid] DefaultCellRenderer and wordwrap [message #592373 is a reply to message #59466] Sat, 27 September 2008 16:26 Go to previous message
> When using
> narrower.
> Help?
> Regards
> Greg
Previous Topic:gantt charts synchronize
Next Topic:[Grid] ComboBoxCellEditor doesn't return focus to the Grid
Current Time: Fri Nov 07 22:27:24 EST 2025
Powered by FUDForum. Page generated in 0.03961 seconds
