Home » Archived » Visual Editor (VE) » VE and SWT
VE and SWT [message #59354] Fri, 10 September 2004 09:31 Go to next message
Hello there..
Just installed E3 and VE1 latest builds..
When I try to create an SWT application and fire it up, I receive these
messages below. What can I do?
Henrik
java.lang.UnsatisfiedLinkError: no swt-win32-3062 in java.library.path
at java.lang.ClassLoader.loadLibrary(Unknown Source)
at java.lang.Runtime.loadLibrary0(Unknown Source)
at java.lang.System.loadLibrary(Unknown Source)
at org.eclipse.swt.internal.Library.loadLibrary(Library.java:10 0)
at org.eclipse.swt.internal.win32.OS.<clinit>(OS.java:18)
at org.eclipse.swt.graphics.Device.init(Device.java:564)
at org.eclipse.swt.widgets.Display.init(Display.java:1780)
at org.eclipse.swt.graphics.Device.<init>(Device.java:100)
at org.eclipse.swt.widgets.Display.<init>(Display.java:355)
at org.eclipse.swt.widgets.Display.<init>(Display.java:351)
at org.eclipse.swt.widgets.Display.getDefault(Display.java:993)
at myApp.main(myApp.java:26)
Exception in thread "main"
Re: VE and SWT [message #59404 is a reply to message #59354] Fri, 10 September 2004 12:24 Go to previous messageGo to next message
Originally posted by: myersj.nospam.gmail.com
Hi Henrik,
You need to add the path to the SWT dll to your java.library path in
order to run SWT code. See:
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/plat form-swt-home/faq.html#standalone
When you're using the VE to develop SWT code, you should use the Run
As->Java Bean function. This will handle the setup of the SWT library
paths for you automatically.
- Jeff
Henrik Skovgaard wrote:
> Hello there..
> Henrik
Re: VE and SWT [message #59625 is a reply to message #59404] Mon, 13 September 2004 02:47 Go to previous message
"Jeff Myers" <myersj@nospam.gmail.com> wrote in message
news:chsk8q$7nt$1@eclipse.org...
> Hi Henrik,
> You need to add the path to the SWT dll to your java.library path in order
Thanks Jeff, that helped me out :-)
/Henrik
Re: VE and SWT [message #598314 is a reply to message #59354] Fri, 10 September 2004 12:24 Go to previous message
Hi Henrik,
- Jeff
> Hello there..
> Henrik
Re: VE and SWT [message #598378 is a reply to message #59404] Mon, 13 September 2004 02:47 Go to previous message
> Hi Henrik,
/Henrik
Previous Topic:Background of JPanel
Next Topic:Background of JPanel
Current Time: Sun Nov 30 18:39:39 EST 2025
Powered by FUDForum. Page generated in 0.04506 seconds
