Home » Language IDEs » AspectJ » AJDT 1.2.1RC1 and 1.3.0RC1 now available
AJDT 1.2.1RC1 and 1.3.0RC1 now available [message #59330] Wed, 14 December 2005 18:01 Go to next message
We're pleased to announce the availability of:
AJDT 1.2.1RC1 for Eclipse 3.0 and
AJDT 1.3.0RC1 for Eclipse 3.1
They are available from the AJDT downloads page:
http://www.eclipse.org/ajdt/downloads/
The exact build levels are 1.2.1.20051214160017 and
1.3.0.20051214130641, which match the latest development builds at the
time of writing - if you have those already, then there is no need to
upgrade as they are the same. If you are using any previous release or
development builds, please try out either or both of these RC1
releases to help us make the final releases as good as possible.
Please use Bugzilla to raise any problems encountered.
It's probably obvious, but just for the record: these RC1 builds of
AJDT contain AspectJ 5 RC1.
The AJDT team.
Re: AJDT 1.2.1RC1 and 1.3.0RC1 now available [message #59361 is a reply to message #59330] Thu, 15 December 2005 03:34 Go to previous messageGo to next message
When I point Eclipse at
http://download.eclipse.org/technology/ajdt/31/update, I get this Features
To Install dialog:
Eclipse AspectJ Development Tools 1.2.0.20050413151050
Is this correct?
Re: AJDT 1.2.1RC1 and 1.3.0RC1 now available [message #59436 is a reply to message #59361] Thu, 15 December 2005 04:09 Go to previous message
> To Install dialog:
> Is this correct?
No, it should be 1.3.0.20051214130641
There is probably some caching happening between you and the update site,
and you're still seeing the old one (the same happens to us sometimes).
Try opening this URL in a browser:
http://download.eclipse.org/technology/ajdt/31/update/site.x ml
You should see some XML describing the feature, with a version number.
If it's the old version, hold down Control and hit Refresh. It should
reload with the new version number. If so, restart Eclipse, and return to
the update site, and the correct version should appear.
Hope that helps,
Matt.
Re: AJDT 1.2.1RC1 and 1.3.0RC1 now available [message #591270 is a reply to message #59330] Thu, 15 December 2005 03:34 Go to previous message
To Install dialog:
Is this correct?
Re: AJDT 1.2.1RC1 and 1.3.0RC1 now available [message #591287 is a reply to message #59361] Thu, 15 December 2005 04:09 Go to previous message
> To Install dialog:
> Is this correct?
Hope that helps,
Matt.
Previous Topic:Newbie has Eclipse 3.1.1 - which version of AJDT ??
Next Topic:(again) Eclipse doesn't recognize introduced method
Current Time: Mon Jul 21 23:45:46 EDT 2025
Powered by FUDForum. Page generated in 0.08303 seconds
