Home » Eclipse Projects » Equinox » PDE Manifest editor - classpath utility is kind of confusing
PDE Manifest editor - classpath utility is kind of confusing [message #59274] Wed, 01 February 2006 16:14 Go to next message
I created a bundle with the 3.2M4 PDE that included additional jars
(contained within) in its classpath. I added the jars under the manifest
editor's Runtime tab which was easy enough. However, then when I built my
bundle (via the generated Ant script) the compiled code wasn't included.
It took me a while to track down the issue, but I realized that after
adding libraries to my classpath, the root of the bundle was no longer
included. This is fine, and adding "." solved the problem, but the PDE
manifest editor doesn't seem to make this fact very obvious. I had to
click "New" to add a new classpath entry, which presented a dialog box
that appeared to be geared towards adding additional libraries (jars).
E.g., the input box in the dialog is initially filled with "library.jar",
with "library" highlighted so that it can easily be overwritten.
Does this seem unintuitive to anyone else? Is there somewhere else that
allows me to specify that I want the bundle's root included in the
classpath?
Jeremy Volkman
Re: PDE Manifest editor - classpath utility is kind of confusing [message #59350 is a reply to message #59274] Thu, 02 February 2006 02:43 Go to previous messageGo to next message
> classpath?
Yes, we have this problem too. We add the "Bundle-Classpath: .," etc in
the Manifest via the text editor view. it then appears in the runtime
box, but I don't think there is another way yet. Very confusing when
running your bundles outside the PDE.
/peter
Re: PDE Manifest editor - classpath utility is kind of confusing [message #60526 is a reply to message #59350] Thu, 09 February 2006 11:40 Go to previous message
Originally posted by: jeff_nospam_mcaffer.ca.ibm.com
Interesting. Could you enter a bug report against PDE UI with the details
of your workflow.
Thanks!
Jeff
"Peter Neubauer" <pnb@scancoin.se> wrote in message
news:drsd81$2db$1@utils.eclipse.org...
> > classpath?
> /peter
Previous Topic:[Fwd: Re: Eclipse 3.1 Test Framwork : org.eclipse.ant.optional.junit\fragment.xml broken?]
Next Topic:Unable to start an OSGi bundle targeted at Eclipse 3.1 while developing with Eclipse 3.2M4
Current Time: Sun Nov 09 13:43:32 EST 2025
Powered by FUDForum. Page generated in 0.05040 seconds
