Home » Archived » XML Schema Definition (XSD) » How to check if a simple type is a restriction of a base type ?
How to check if a simple type is a restriction of a base type ? [message #59258] Wed, 20 April 2005 11:21 Go to next message
Originally posted by: ediouf.genigraph.fr
Hi every body,
I would like to check if a simple type : "mySimpleType" is a restriction
of a base type : "integer" for exemple?
How can i do it?
Thanks for your reply ?
Re: How to check if a simple type is a restriction of a base type ? [message #59307 is a reply to message #59258] Wed, 20 April 2005 14:54 Go to previous message
--------------040202060308050208060008
Elhadji,
This method in XSDUtil does something similar to what you want to do:
* Returns whether the simple type definition is the
* <a href="http://www.w3.org/TR/xmlschema-2/#dt-ID">ID</a>.
* @param xsdSimpleTypeDefinition a simple type definition.
* @return whether the simple type definition is
public static boolean isOrIsDerivedFromID(XSDSimpleTypeDefinition
xsdSimpleTypeDefinition)
while (xsdSimpleTypeDefinition != null)
if (isURType(xsdSimpleTypeDefinition))
return false;
if
(isSchemaForSchemaNamespace(xsdSimpleTypeDefinition.getTarge tNamespace())
"ID".equals(xsdSimpleTypeDefinition.getName()))
return true;
xsdSimpleTypeDefinition =
xsdSimpleTypeDefinition.getBaseTypeDefinition();
return false;
You'll want to be careful going up the type hierarchy that you don't
loop forever on the anyType.
Elhadji wrote:
> Hi every body,
> restriction of a base type : "integer" for exemple?
> How can i do it?
<html>
<head>
http-equiv="Content-Type">
</head>
Elhadji,<br>
<br>
This method in XSDUtil does something similar to what you want to do:<br>
<blockquote><small>
Re: How to check if a simple type is a restriction of a base type ? [message #594790 is a reply to message #59258] Wed, 20 April 2005 14:54 Go to previous message
Elhadji,
return false;
if
return true;
return false;
Elhadji wrote:
> Hi every body,
> How can i do it?
<html>
<head>
</head>
Elhadji,<br>
<br>
<blockquote><small>
Previous Topic:How to check if a simple type is a restriction of a base type ?
Next Topic:EStructuralFeature for the XSDSchema
Current Time: Thu Nov 06 17:54:34 EST 2025
Powered by FUDForum. Page generated in 0.04232 seconds
