Home » Eclipse Projects » Technology Project and PMC » question about CVS
| question about CVS [message #59238] |
Thu, 16 October 2003 19:38  |
Hello, sorry if i'm posting to wrong newsgroup.
Can somebody explain me,how to use the local CVSROOT?
My CVSROOT is /usr/local/cvs, and it seems that Eclipse does not understand
this, it wants me to specity server/port/protocol.
How can i fix that?
Thank you,best regards
Eugene N Dzhurinsky
http://JDevelop.com - dedicated Java-based WEB solutions
ICQ: 119576351
Cell:+(380)-677-940549
| Re: question about CVS [message #59264 is a reply to message #59238] |
Fri, 17 October 2003 05:47   |
>How can i fix that?
Hi Eugeny,
Eclipse needs a CVS server to talk to, that's why its asking for
server/port/protocol. You could use that directory as your project's
directory, but then you don't have the CVS features that you probably
want to have (revisions, versions, branches etc.)
| Re: question about CVS [message #59285 is a reply to message #59264] |
Fri, 17 October 2003 09:30   |
>>understand this, it wants me to specity server/port/protocol.
>>How can i fix that?
> Hi Eugeny,
Hmm, seems that i have to use stand-alone CVS client to deal with.
Okay, thanks for reply :)
Eugene N Dzhurinsky
ICQ: 119576351
AIM: EugenyDzh
| Re: question about CVS [message #59311 is a reply to message #59285] |
Fri, 17 October 2003 09:44   |
>>>How can i fix that?
>>Hi Eugeny,
Do you have a CVS server running or not? I'm getting a bit confused what
the problem actually is :)
| Re: question about CVS [message #59528 is a reply to message #59335] |
Wed, 22 October 2003 10:36  |
Originally posted by: Michael_Valenta.oti.com
Eugeny,
The reason Eclipse doesn't work with local CVS repositories is because
Elipse has its own CVS client while other tools typically access CVS by
invoking the CLI tool. Early on in Eclipse, it was decided that the
benefits of having a client in Eclipse (i.e. tools such as the repo
browser and sync view) outweighed the disadvantages (some unsupported
features such as local connection method).
Michael
> well, i don't have CVS server running because i don;t need it to be running,
> but you know CVS client may deal with the local filesystem. So i guess that
> eclipse may deal only with CVS server, right?
> I added the cvspserver service to inetd.conf, it seems to work now, but i
> don't understand why i have to start CVS server if everything works fine
> without it (but not in Eclipse). For example, IntelliJ IDEA works fine with
> this project, without any CVS server running.
| Re: question about CVS [message #595788 is a reply to message #59238] |
>How can i fix that?
Hi Eugeny,
| Re: question about CVS [message #595797 is a reply to message #59264] |
>>How can i fix that?
> Hi Eugeny,
Eugene N Dzhurinsky
ICQ: 119576351
AIM: EugenyDzh
| Re: question about CVS [message #595805 is a reply to message #59285] |
>>>How can i fix that?
>>Hi Eugeny,
| Re: question about CVS [message #595812 is a reply to message #59311] |
Fri, 17 October 2003 14:15  |
Eugene N Dzhurinsky
ICQ: 119576351
| Re: question about CVS [message #595900 is a reply to message #59335] |
Eugeny,
Michael
Current Time: Fri Nov 21 12:01:17 EST 2025
Powered by FUDForum. Page generated in 0.05884 seconds
