Home » Modeling » GMF (Graphical Modeling Framework) » Removing the popup menus
Removing the popup menus [message #59193] Wed, 04 October 2006 14:01 Go to next message
Originally posted by: amolin.sktcorp.com
GMF automatically creates a palette of icons when you hover the mouse in
an editor window--the palette of things that can be inserted into the
current object. My boss does not like the look of it; is there any simple
way to turn it off?
Thanks!
Arthur Molin
Re: Removing the popup menus [message #59346 is a reply to message #59193] Thu, 05 October 2006 04:49 Go to previous messageGo to next message
Originally posted by: 5d5.mail.ru
Remove edit policy with key EditPolicyRoles.POPUPBAR_ROLE from all node
and compartment edit parts. Or PopupBarEditPolicy if it's registered by
other key.
> simple way to turn it off?
> Thanks!
> Arthur Molin
Re: Removing the popup menus [message #59956 is a reply to message #59346] Fri, 06 October 2006 07:33 Go to previous message
Arthur,
You could also easily control this with a preference option if you
wanted. Support for this is already in GMF. The GMF Logic Diagram
Example has this in its preference pages.
- Cherie
> other key.
>> in an editor window--the palette of things that can be inserted into
>> the current object. My boss does not like the look of it; is there any
>> Thanks!
>> Arthur Molin
Previous Topic:Compartment using multiple EString
Next Topic:Drawing custom decorations in Compartment-Nodes
Current Time: Sat Nov 08 01:19:40 EST 2025
Powered by FUDForum. Page generated in 0.02864 seconds
