Home » Eclipse Projects » Plugin Development Environment (PDE) » Declare an extension as optional?
Declare an extension as optional? [message #59128] Thu, 30 April 2009 18:31 Go to next message
Hey all,
i have an UML profile (don't panic, it is no UML-specific questions),
which i want to reuse for several IDE's (Papyrus, RSM, etc.), but every
IDE has its own internal registration mechanism via an Extension Point.
Is it possible to declare in one plugin, several extension and set these
extensions to a kind of "optional"? The problem is, that if the required
plugin was not found in the environment, the whole plugin will not be
registered! But, i didn't want to duplicate the Profile/Resource/What
ever for every new IDE.
Thanks a lot
Timothy
Re: Declare an extension as optional? [message #59203 is a reply to message #59128] Fri, 01 May 2009 18:17 Go to previous messageGo to next message
Hey Timothy, > Is it possible to declare in one plugin, several
> registered!
Is it possible to programatically register an extension at runtime?
Felix
Re: Declare an extension as optional? [message #59228 is a reply to message #59203] Sat, 02 May 2009 05:57 Go to previous messageGo to next message
Felix,
what do you want to say with this fragment? Was this an additional
question or an answer? :)
Timothy
>> required plugin was not found in the environment, the whole plugin
>> will not be registered!
> Felix
Re: Declare an extension as optional? [message #59278 is a reply to message #59228] Sat, 02 May 2009 09:32 Go to previous message
Hey Timothy. Sorry. I wanted to say: If it is possible to
programatically register an extension at runtime, then you could do:
if (plugin1 is present){
register extension for plugin1
Now we just need someone who can answer my question. Then yours would be
answered too :-)
Felix
Re: Declare an extension as optional? [message #596652 is a reply to message #59128] Fri, 01 May 2009 18:17 Go to previous message
> registered!
Felix
Re: Declare an extension as optional? [message #596662 is a reply to message #59203] Sat, 02 May 2009 05:57 Go to previous message
Felix,
Timothy
> Felix
Re: Declare an extension as optional? [message #596680 is a reply to message #59228] Sat, 02 May 2009 09:32 Go to previous message
answered too :-)
Felix
Previous Topic:Toolbar contributions not shown in Customize Perspective dialog
Next Topic:"Build site" debugging
Current Time: Sun Jul 13 06:38:30 EDT 2025
Powered by FUDForum. Page generated in 0.04565 seconds
