| Re: Newbie has Eclipse 3.1.1 - which version of AJDT ?? [message #591161 is a reply to message #59109] |
Wed, 14 December 2005 09:40  |
Kevin wrote:
> I have Eclipse 3.1.1 running on XP Professional.
> Which version of AJDT should I install that is compatible with this
> Eclipse version?
> Should I use the internal Eclipse installer and point it to
> http://download.eclipse.org/technology/ajdt/31/update/ ??
> Would someone please tell me if that will even work?
> Or is there a better, more stable way of installing the AspectJ components
> into this Eclipse environment?
Hi Kevin,
There isn't quite a stable AJDT release for Eclipse 3.1.1 yet - it's
waiting on the final release of AspectJ 5. Until then you can point the
installer at:
http://download.eclipse.org/technology/ajdt/31/dev/update/
and pick up the latest AJDT development build. As we are so close to
release, these builds should be stable. In fact AspectJ 5 RC1 has just
been released today, so there should also be an AJDT 1.3.0 RC1 released
within a day.
Matt.
| Re: Newbie has Eclipse 3.1.1 - which version of AJDT ?? [message #591186 is a reply to message #59135] |
Wed, 14 December 2005 10:33  |
Thanks, Matt.
I pointed the installer to the URL in my first message and when Eclipse
restarted it sort of freaked out.
Any project I now click on shows on dumps error messages in the log, for
example:
Caused by: java.lang.NullPointerException
org.eclipse.ajdt.ui.AspectJUIPlugin.checkProblemMarkersVisib le(AspectJUIPlugin.java:491)
org.eclipse.ajdt.ui.AspectJUIPlugin.checkAspectJVersion(Aspe ctJUIPlugin.java:470)
at org.eclipse.ajdt.ui.AspectJUIPlugin.start(AspectJUIPlugin.ja va:674)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:994)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:988)
... 77 more
I will try your URL and see what happens next.
Best,
Kevin
| Re: Newbie has Eclipse 3.1.1 - which version of AJDT ?? [message #591191 is a reply to message #59160] |
Wed, 14 December 2005 11:09  |
There appears to be a very old build there, but there shouldn't be
anything there as yet (until we release RC1). Where did you get that URL
from? It's not listed on the AJDT download page here:
http://www.eclipse.org/ajdt/downloads/
I'm sure a current build will work much better!
Matt.
| Re: Newbie has Eclipse 3.1.1 - which version of AJDT ?? [message #591203 is a reply to message #59135] |
Wed, 14 December 2005 11:12  |
Hi Matt,
This could be a simple project configuration mistake of mine, but when
after I add the aspect nature to an existing project and then add a new
aspect construct, I get the following exception. Why can't the mail.jar in
my Java Build Path not be opened?
Best,
Kevin
org.aspectj.weaver.BCException
org.aspectj.weaver.bcel.ClassPathManager$ZipFileEntry.ensure Open(ClassPathManager.java:253)
org.aspectj.weaver.bcel.ClassPathManager$ZipFileEntry.find(C lassPathManager.java:225)
at org.aspectj.weaver.bcel.ClassPathManager.find(ClassPathManag er.java:92)
at org.aspectj.weaver.bcel.BcelWorld.lookupJavaClass(BcelWorld. java:272)
at org.aspectj.weaver.bcel.BcelWorld.resolveDelegate(BcelWorld. java:247)
at org.aspectj.weaver.World.resolveToReferenceType(World.java:3 00)
at org.aspectj.weaver.World.resolve(World.java:217)
at org.aspectj.weaver.World.resolve(World.java:137)
at org.aspectj.weaver.World.resolve(World.java:265)
org.aspectj.ajdt.internal.core.builder.AjBuildManager.initBc elWorld(AjBuildManager.java:670)
org.aspectj.ajdt.internal.core.builder.AjBuildManager.doBuil d(AjBuildManager.java:209)
org.aspectj.ajdt.internal.core.builder.AjBuildManager.batchB uild(AjBuildManager.java:156)
org.aspectj.ajde.internal.CompilerAdapter.compile(CompilerAd apter.java:122)
org.aspectj.ajde.internal.AspectJBuildManager$CompilerThread .run(AspectJBuildManager.java:191)
BCException thrown: Can't open archive: mail.jar
when batch building
BuildConfig[C:\development\workspace\.metadata\.plugins\org. eclipse.ajdt.core\trading.generated.lst]
#Files=32
| Re: Newbie has Eclipse 3.1.1 - which version of AJDT ?? [message #591227 is a reply to message #59183] |
Wed, 14 December 2005 11:23  |
> Matt.
Perhaps. I am assuming first that my Java Project in Eclipse is wrongly
configured.
It has been a long time since I have checked out sources from cvs and
compiled them locally, so I think I will wait for that RC you mentioned.
Unless you can point me to an URL which covers this process using Eclipse
and your pserver?
Many Thanks,
Kevin
FUDForum. Page generated in 0.07749 seconds
