Home » Archived » XML Schema Definition (XSD) » How to get the XSDAttributeUse from a DOM-Node?
How to get the XSDAttributeUse from a DOM-Node? [message #58978] Mon, 04 April 2005 07:52 Go to next message
Originally posted by: runinpanic.gmx.de
I would like to have the XSDAttributeUse-object returned from a Node
(that I get using an Xpath-Expresssion) I kknow the way to get the
XSDConcreteComponent of a node using
SCHEMA.getCorrespondingComponent(Node) ... but that method only returns
a XSDAttributeDeclaration when having an Attribute-Node given. How can i
get the XSDAttributeUse-object that contains that
XSDAttributeDeclaration?
Thank you for your help
Hajo Hoffmann
Re: How to get the XSDAttributeUse from a DOM-Node? [message #59006 is a reply to message #58978] Mon, 04 April 2005 08:07 Go to previous message
Hajo,
Probably the getContainer of the XSDAttributeDeclaration will be the
XSDAttributeUse.
Hajo Hoffmann wrote:
>Hi
>Regards
> Hajo Hoffmann
Re: How to get the XSDAttributeUse from a DOM-Node? [message #594668 is a reply to message #58978] Mon, 04 April 2005 08:07 Go to previous message
Hajo,
XSDAttributeUse.
>Hi
>Regards
> Hajo Hoffmann
Previous Topic:How to get the XSDAttributeUse from a DOM-Node?
Next Topic:Problems with <redefine>
Current Time: Fri Nov 07 14:52:17 EST 2025
Powered by FUDForum. Page generated in 0.03369 seconds
