Home » Archived » Visual Editor (VE) » Linux work spaces
Linux work spaces [message #58956] Thu, 09 September 2004 10:34 Go to next message
Originally posted by: junk.guenthermatthias.de
if I have opened a class with the VE in my eclipse 3.0 I can not change
to another work space on my Suse KDE.
What could be the problem?
Thanks in advance.
Re: Linux work spaces [message #58983 is a reply to message #58956] Thu, 09 September 2004 10:36 Go to previous messageGo to next message
Originally posted by: richkulp.NO.SPAM.us.ibm.com
What are the symptoms? Is there a .log file with errors? What do you
mean you can't change to another workspace? If you close the workspace
you can't open another one?
Thanks, Rich Kulp
Re: Linux work spaces [message #59008 is a reply to message #58983] Thu, 09 September 2004 10:49 Go to previous messageGo to next message
I do not find a .log in my eclipse folder or in workspace folder.
But I think I have not explained it right. I do not mean the eclipse
workspaces! I mean the workspaces of my KDE. Some applications are on
workspace 1 some on workspace 2. If I open a class in VE I get a Form in
my Taskbar too. This form I can not close. If I try to change to another
KDE workspace I can see it for a short moment with this "dummy" Form,
and than I will be thrown back to the workspace where eclipse is opened.
Matthias
Re: Linux work spaces [message #59032 is a reply to message #59008] Thu, 09 September 2004 11:15 Go to previous messageGo to next message
I don't know anything about KDE, but if you are talking about seeing a
shell in the screen's taskbar (?), that happens. We create a live
instance of the shell being edited so that we can screen-scrape it to
put the picture into the VE. Unfortunately this live shell often shows
up in the taskbar. We also put it way off screen, but some screen
managers don't allow that and they force it back onto the screen. But I
don't see how that should stop KDE from switching, after all it is no
different than any other shell.
Thanks, Rich Kulp
Re: Linux work spaces [message #59081 is a reply to message #59032] Thu, 09 September 2004 12:05 Go to previous messageGo to next message
Yes I see the shell in my taskbar.
Hm, maybe there are some other guys here who use KDE and can confirm
this problem or maybe have a solution for it.
Thanks.
Re: Linux work spaces [message #65963 is a reply to message #59081] Sun, 10 October 2004 08:48 Go to previous messageGo to next message
I'm using KDE3.2 on Suse Linux 9.1.
Switching visual-workspaces works fine with me.
Perhaps your hardware-configuration is too slow to manage it correctly or
your Eclipse/VE has a problem. Don't close the windows created by the VE.
Perhaps a restart of the Eclipse with ./eclipse -clean helps.
spunti
Re: Linux work spaces [message #67907 is a reply to message #65963] Wed, 20 October 2004 11:51 Go to previous messageGo to next message
> spunti
No, it doesn't work fine! The problem of not being able to switch the
view-workspace (of KDE) occurs only when using SWT-GUIs with VE.
Did you find out a fix for this problem, Matthias?
This behaviour is a big problem, I would say.
spunti
Re: Linux work spaces [message #68675 is a reply to message #67907] Fri, 22 October 2004 11:40 Go to previous message
> spunti
I put my comment to an open bug int the bugzilla-system, now.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=71291
Re: Linux work spaces [message #598208 is a reply to message #58956] Thu, 09 September 2004 10:36 Go to previous message
Thanks, Rich Kulp
Re: Linux work spaces [message #598216 is a reply to message #58983] Thu, 09 September 2004 10:49 Go to previous message
Matthias
Re: Linux work spaces [message #598223 is a reply to message #59008] Thu, 09 September 2004 11:15 Go to previous message
Thanks, Rich Kulp
Re: Linux work spaces [message #598233 is a reply to message #59032] Thu, 09 September 2004 12:05 Go to previous message
Thanks.
Re: Linux work spaces [message #601195 is a reply to message #59081] Sun, 10 October 2004 08:48 Go to previous message
spunti
Re: Linux work spaces [message #602059 is a reply to message #65963] Wed, 20 October 2004 11:51 Go to previous message
> spunti
spunti
Re: Linux work spaces [message #602234 is a reply to message #67907] Fri, 22 October 2004 11:40 Go to previous message
> spunti
Previous Topic:What is the need for EMF model when BeanDeclModel is being built?
Next Topic:1.0.1.1 is now available
Current Time: Sat Nov 08 08:08:22 EST 2025
Powered by FUDForum. Page generated in 0.15610 seconds
