Home » Eclipse Projects » Remote Application Platform (RAP) » WYSIWYG and portlet environment
WYSIWYG and portlet environment [message #58935] Fri, 09 November 2007 05:37 Go to next message
Originally posted by: markus.groh.seat.de
Hi all,
i've got two questions:
1. Is there a WYSIWYG-Editor for building RAP GUI's?
2. Is it possible to run RAP based applications in a portlet environment
(liferay 4.3)? Are there any examples?
Markus
Re: WYSIWYG and portlet environment [message #58961 is a reply to message #58935] Fri, 09 November 2007 07:05 Go to previous messageGo to next message
To answer the wisiwyg question, have you tried Visual Editor, or Window
Builder de Instantiation?
regards
xavier
Re: WYSIWYG and portlet environment [message #59113 is a reply to message #58935] Fri, 09 November 2007 15:10 Go to previous messageGo to next message
Originally posted by: eclipse-dev.volanakis.de
Reg. 1: AFAIK there is no WYSIWYG editor for RAP out there. The closest
thing is to use an WYSIWYG editor for SWT and then to port the resulting
code.
These are the SWT UI editors I'm aware of:
- Visual Editor (latest stable release for Eclipse 3.2 only, free)
- SWT Designer by Instantiations ($, free for non-commercial use)
- Jigloo SWT/Swing GUI Builder by Cloudgarden ($, free for non-com. use)
Elias.
Markus wrote:
> Hi all,
> Markus
Re: WYSIWYG and portlet environment [message #59134 is a reply to message #59113] Fri, 09 November 2007 17:07 Go to previous messageGo to next message
Originally posted by: jkrause.innoopract.com
What do you mean with "port the resulting code"?
As RWT provides a subset of SWT, the one thing that may occur is that
generated code contains API that RWT does not (yet) support.
In many cases the generated code will work, and in some cases not - in
the latter case you need to get rid of the none supported api, I
wouldn't call that porting.
> code.
> Elias.
> Markus wrote:
>> Hi all,
>> environment (liferay 4.3)? Are there any examples?
>> Thanks,
>> Markus
Re: WYSIWYG and portlet environment [message #59659 is a reply to message #58935] Wed, 14 November 2007 04:59 Go to previous message
Originally posted by: fappel.innoopract.com
see
http://dev.eclipse.org/newslists/news.eclipse.technology.rap /msg00021.html
for portlet environment question.
Ciao
Frank
"Markus" <markus.groh@seat.de> schrieb im Newsbeitrag
news:0131c04c73bc859f9906a30abf86ddad$1@www.eclipse.org...
> Hi all,
> Markus
Previous Topic:Offline mode and relationship with GoogleGears
Next Topic:Problem with GMap widget
Current Time: Mon Jul 21 21:35:55 EDT 2025
Powered by FUDForum. Page generated in 0.05001 seconds
