Vertical text alignment in Grid (table viewer)? [message #58923] |
Sat, 06 September 2008 04:23  |
I need vertical text alignment in a column which has large images (~3 x
height of font) so that the text appears aligned with the middle of the
image.
Can't see standard provision for this, right?
I can achieve this by copying & editing DefaultCellRenderer, however I
would've thought other folks might also like a
setVerticalAlignment(SWT.TOP/CENTER/BOTTOM) method on GridColumn, no?!
Justin
Re: Vertical text alignment in Grid (table viewer)? [message #592163 is a reply to message #58923] |
Sat, 06 September 2008 07:32  |
File a bugzilla and in the ideal case you provide a patch for
DefaultCellRenderer which has this feature.
Tom
Justin schrieb:
> image.
> Justin
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: Vertical text alignment in Grid (table viewer)? [message #592189 is a reply to message #58950] |
Mon, 08 September 2008 11:14  |
Hi Tom,
Sure will do, can supply a patch too. Guess I should raise an enhancement
request rather than a bug?
Justin
Tom Schindl wrote:
> Tom
> Justin schrieb:
>> image.
>> Thanks,
>> Justin
FUDForum. Page generated in 0.03911 seconds
