| Possible to Pass Parameters To AGR Verification Hooks? [message #58840] |
Thu, 16 March 2006 11:18  |
Originally posted by: jhouston.bea.com
My use case is: I record a test case that creates a new file and I want
to be able to use the new file test case like a "method" in another test
suite's test behavior. I'd like to be able to add a verification hook
that can execute a file diff on the new file against a baseline, but the
baseline file will be different depending on the givn user input. Is
there any way to pass in parameters to the verification methods?
If not, is there a way to call into a verification hook without
requiring UI input? For example, in my test behavior I want to be able
to insert a callback to the underlying JUnit file without having to
launch the recorder. If this is possible (and there is a way to get the
test cases in a test suite's behavior to run in sequence) then it would
be possible to add specifica callbacks where "parameters" can be static
constants in the JUnit file.
Any help?
| Re: Possible to Pass Parameters To AGR Verification Hooks? [message #61168 is a reply to message #58840] |
Tue, 28 March 2006 10:31  |
You can't pass in an arbitrary parameter to a verification hook.
You can insert a verification hook after the creation of your file and
assume certain properties before doing the verification. For example, you
can assume a certain value for the user input and do the verification based
on that assumption. This will of course require you to create x test cases
for x user inputs. A smarter approach would be to separate the actual
creation of the file from the verification.
For example:
- Create one test case that will create the file (let's call this test case
A)
- Create multiple test cases that will only contain a verification hook to
do your verification. (let's call these test cases B1, B2, ...Bn). The
verification hooks will ignore the target parameter and only perform the
file diff to do the verification.
Under your behavior page, you can have something like
Test case A (linked to user input 1)
Test case B1 (assumes user input 1 before doing the verification)
Test case A (linked to user input 2)
Test case B2 (assumes user input 2 before doing the verification)
Test case A (linked to user input n)
Test case Bn (assumes user input n before doing the verification)
"John Houston" <jhouston@bea.com> wrote in message
news:dvc39k$pt4$1@utils.eclipse.org...
> Any help?
FUDForum. Page generated in 0.03578 seconds
