Home » Language IDEs » AspectJ » Library aspectrt.jar with Internet Explorer JVM : compatible or not ?
Library aspectrt.jar with Internet Explorer JVM : compatible or not ? [message #58833] Wed, 23 November 2005 12:44 Go to next message
Originally posted by: ahugueney.fininfo.fr
I tried and used aspectjrt.jar (eclipse 3.1) with Internet Explorer JVM
(5.0.0.3810 / XP sp2). But it failed with a very simple pointcut (trace).
The same worked with the Sun plug-in (JDK 1.5.0_05).
So I guess that the bytecode produced by the AspectJ tools (built from
17/11/2005) are lacking some important compatibility with Internet Explorer
JVM.
But the documentation referenced at
http://www.eclipse.org/aspectj/doc/next/devguide/compatibili ty.html#javaCompatibility
says that it should run. So how could I manage to fix this in someway ?
Thanks a lot in advance,
Antoine Hugueney (Java programmer)
Re: Library aspectrt.jar with Internet Explorer JVM : compatible or not ? [message #58859 is a reply to message #58833] Thu, 24 November 2005 03:25 Go to previous message
Originally posted by: clemas.uk.ibm.com
What kind of failure do you see? aspectjrt.jar is a Java 1.1 compliant
module - we don't do explicit testing with the JVMs in web browsers but
if it doesn't work then it sounds like a bug.
Andy.
> JVM.
Re: Library aspectrt.jar with Internet Explorer JVM : compatible or not ? [message #591021 is a reply to message #58833] Thu, 24 November 2005 03:25 Go to previous message
Andy.
> JVM.
Previous Topic:Library aspectrt.jar with Internet Explorer JVM : compatible or not ?
Next Topic:Release?
Current Time: Sat Nov 15 07:55:41 EST 2025
Powered by FUDForum. Page generated in 0.03877 seconds
