Home » Archived » M2M (model-to-model transformation) » [ATL] : Using a Set in the "from" action
[ATL] : Using a Set in the "from" action [message #58826] Tue, 21 August 2007 04:17 Go to next message
Originally posted by: youssef.srour.etu.univ-nantes.fr
If we declare in the "from" the variable:
from classes : Set(UML!Class)
what is going to take place in the execution and who the ATL engine is
going to execute the actions ?
Thank you
Youssef
Re: [ATL] : Using a Set in the "from" action [message #59001 is a reply to message #58826] Tue, 21 August 2007 17:07 Go to previous message
The current version of ATL does not support this kind of source pattern.
Could you please elaborate on the context in which you want to use it?
Then we may be able to find a solution.
Frédéric Jouault
Previous Topic:[ATL] New use case - Variability management in MDSPL
Next Topic:[ATL]Problem generating Model
Current Time: Wed Jul 16 20:51:32 EDT 2025
Powered by FUDForum. Page generated in 0.09832 seconds
