Home » Newcomers » Newcomers » using separate jdk compilers
using separate jdk compilers [message #58812] Thu, 28 April 2005 05:55 Go to next message
How can I have different projects use different jdk versions? Currently,
when I change the jdk eclipse recompiles my whole workspace. But what i
want is some projects to use jdk1.4 and others jdk1.5
thanks
Re: using separate jdk compilers [message #58888 is a reply to message #58812] Thu, 28 April 2005 07:32 Go to previous messageGo to next message
Originally posted by: hcs33.egon.gyaloglo.hu
There is a 'global' default jdk/jre setting under Preferences. By default
all java projects will use that one. But - if you want to change it for a
project - you can do it:
1. Project properties > Java build path > Libraries.
2. Select 'JRE system library' and 'Edit...'.
3. In the dialog you can select an alternative JDK/JRE from the installed
ones.
Also, in the 'Project properties' you can set different compiler options
than the default one (comes from Preferences) if necessary.
HTH,
Csaba
> thanks
Re: using separate jdk compilers [message #58938 is a reply to message #58888] Thu, 28 April 2005 09:09 Go to previous message
Horváth, Csaba wrote:
> ones.
> HTH,
> Csaba
>>thanks
thanks
Previous Topic:Which newsgroup?
Next Topic:change workspace
Current Time: Sun Nov 30 15:15:43 EST 2025
Powered by FUDForum. Page generated in 0.08150 seconds
