Home » Language IDEs » C / C++ IDE (CDT) » Has this been dealt with... invoking make locks up eclipse
Has this been dealt with... invoking make locks up eclipse [message #58800] |
Mon, 20 January 2003 08:50  |
Originally posted by: nomail.bob.com
Hi there. I'm also having problems with make causing wsad to hang. I found
this from an earlier posting in the newsgroup 4/10/2002 (10/4/2002 for you
americans out there) and this still seems to be a problem for me. When
issuing command /c set I get my path cut off after 4 characters, cmd /c set
however works fine. From what was dicussed in the mentioned thread this is
likely to be causing the eclipse tooling to hang.
Thanks in advance
mail: coxsteph @uk.ibm.com (, remove the space)
Found something that might be of interest here:
On my Windows 2000 SP 3 system, "command.com /c set" results in truncated
data coming back for a number of the larger environment variables, most
notably PATH, especially when entries in the path had spaces in the
pathnames.
Had the hanging problem on the latest build (10/02), with "command.com /c
set" returning my PATH as:
PATH=C:\PRO
That's all, truncated right there, no obvious reason why. Got beyond this
by juggling things around in the path such that mingw and msys were near the
start, and the entries with spaces in the pathnames were at the end.
Interestingly, "cmd /c set" on this system returns complete data for all
environment variables, no truncation. Perhaps one of the Windows wizards
could shed some light on this.
Re: Has this been dealt with... invoking make locks up eclipse [message #58876 is a reply to message #58800] |
Mon, 20 January 2003 11:45   |
Hi Stephan,
The referenced is probably misleading/out of date.
I tried to debug the same thing and the code actually no longer does
"command.com /c set",
instead it knows to use "cmd /c set" correctly.
In my case, (Alex helped me debug and did the fixes) it was because
my environment was larger than 4K. You might want to try getting your
environment variables down below 4K.
See the thread "CVS tags for builds and java/Exception bug in
Win32ProcessEx.c"
specifically the posts on "1/15/2003 5:10pm" and "1/16/2003 12:53pm" for the
final
fix (until it gets into a driver) that fixed the problem for me.
"The stuff we call "software" is not like anything that human society
is used to thinking about. Software is something like a machine, and
something like mathematics, and something like language, and
something like thought, and art, and information...
but software is not in fact any of those other things."
Bruce Sterling - The Hacker Crackdown
Fred A. Kulack - IBM eServer iSeries ERP, Java DB2 access, Jdbc, JTA, etc...
IBM in Rochester, MN (Phone: 507.253.5982 T/L 553-5982)
mailto:kulack@us.ibm.com Personal: mailto:kulack@magnaspeed.net
AOL Instant Messenger: Home:FKulack Work:FKulackWrk
"Stephen Cox" <nomail@bob.com> wrote in message
news:b0gtjb$rb4$1@rogue.oti.com...
set
> Thanks in advance
> pathnames.
> PATH=C:\PRO
the
Re: Has this been dealt with... invoking make locks up eclipse [message #58925 is a reply to message #58800] |
Mon, 20 January 2003 12:34   |
Originally posted by: ash371952.hotmail.com
Could you please elaborate your message?
1) Do you experience hanging during build process? If yes, could you please
provide a little bit more details? Is it possible to get sample project from
you?
2) command.com is deprecated command for Win2000. I guess it exist for DOS
compatibility. Why do you try to use it? In CDT we use cmd.exe for Windows
2000.
set
> Thanks in advance
> pathnames.
> PATH=C:\PRO
the
Re: Has this been dealt with... invoking make locks up eclipse [message #59074 is a reply to message #58925] |
Tue, 21 January 2003 08:30   |
I've installed F1 from the downloads site from eclipse. Currently my path is
weighing in at 4020 bytes which is under the 4k limit mentioned in the
newsgroups: CVS tags for builds and java/Exception bug in Win2Process.ex.c.
This is with all paths reduced to short path names.
I create a new c++ project in wsad v5. I then try to create a file called
hello.cpp this is when it attempts to invoke make and wsad just hangs with
no cpu usage. The crash comes whenever I try to create a file or anything
that kicks off invoking make. I have cygwin installed from www.cygwin.com in
the directory c:\utils\cygwin and my path points to c:\cutils\cygwin\bin
If you need I'll try and create a project where this is re-creatable, but I
do not believe it is due to the project settings themselves, I'm just using
the defaults. I thought that the problem may have been the command /c set
but I've been corrected regarding this.
Now I'm not really sure what is going wrong, maybe it's wsad 5??
Thanks in advance
"Alex Chapiro" <ash371952@hotmail.com> wrote in message
news:b0h9sf$5nt$1@rogue.oti.com...
please
from
> you?
> 2000.
found
you
> set
is
> > Thanks in advance
truncated
> > pathnames.
/c
> > PATH=C:\PRO
this
> the
wizards
Re: Has this been dealt with... invoking make locks up eclipse [message #59099 is a reply to message #59074] |
Tue, 21 January 2003 09:09   |
I don't understand: is 4020 a size of your PATH, or total size environment
(all that set command displays)?
Could you also try the latest version of spawner.dll and starter.exe (I
attached both to this message)?
Alex
news:b0jgpk$er4$1@rogue.oti.com...
is
Win2Process.ex.c.
in
I
using
> Thanks in advance
> please
> from
> > you?
DOS
Windows
> > 2000.
> found
> you
/c
> > set
this
> is
> > > Thanks in advance
> truncated
most
> > > pathnames.
> /c
> > > PATH=C:\PRO
> this
near
> > the
all
> wizards
Attachment: starter.exe
(Size: 16.00KB, Downloaded 127 times)
Attachment: spawner.dll
(Size: 52.00KB, Downloaded 192 times)
Re: Has this been dealt with... invoking make locks up eclipse [message #59146 is a reply to message #59099] |
Tue, 21 January 2003 09:30  |
I got the size of the environment by running: cmd /c set | wc -c
As mentioned in another newsgroup thread. The files you gave me solve the
problem with invoking make, thanks! Now I guess I can get my hands dirty,
sorry for being a pain.
Do I need to do anything to close the bug on bugzilla?
news:b0ji5n$g51$1@rogue.oti.com...
> Alex
path
> is
> Win2Process.ex.c.
called
with
anything
www.cygwin.com
> in
but
> I
> using
set
> > Thanks in advance
> > please
project
> > from
> > > you?
> DOS
> Windows
> > > 2000.
> > found
for
> > you
When
> /c
> > > set
> this
> > is
> > > > Thanks in advance
> > truncated
> most
> > > > pathnames.
"command.com
> > /c
> > > > PATH=C:\PRO
beyond
> > this
> near
> > > the
> all
> > wizards
Current Time: Mon Jul 21 21:58:29 EDT 2025
Powered by FUDForum. Page generated in 0.05651 seconds
