AspectJ project does not clean-build on library change? [message #58784] |
Mon, 21 November 2005 13:52  |
Just curious.
In Eclipse 3.0, AspectJ project will do a rebuild on library change if
auto-build is enabled. In Eclipse 3.1, a library change does not trigger a
rebuild? It does not rebuild to the same result as with Eclipse 3.0. I
need to click the "clean ..." menu item to trigger a clean-build to clean
all those library related compile error marks.
Re: AspectJ project does not clean-build on library change? [message #58809 is a reply to message #58784] |
Tue, 22 November 2005 09:52  |
Hi Harry,
This looks like a bug I just fixed -
https://bugs.eclipse.org/bugs/show_bug.cgi?id=91420. It should work in
the latest development builds of AJDT.
Sian
harry sheng wrote:
> Just curious.
> a rebuild? It does not rebuild to the same result as with Eclipse 3.0. I
> clean all those library related compile error marks.
Re: AspectJ project does not clean-build on library change? [message #591002 is a reply to message #58784] |
Hi Harry,
https://bugs.eclipse.org/bugs/show_bug.cgi?id=91420 It should work in
Sian
harry sheng wrote:
> Just curious.
FUDForum. Page generated in 0.05381 seconds
