Home » Archived » Visual Editor (VE) » Problem with VE on Eclipse 3.0
Problem with VE on Eclipse 3.0 [message #58733] Sun, 05 September 2004 13:05 Go to next message
Originally posted by: bud.curtis.direcway.com
After moving the plugins and features subfolders into the Eclipse 3.0
install, VisualEdit does not appear. The 3.0 install is about three weeks
old.
The installed ZIPS (which I downloaded today from the 1.0M2 download page)
are:
Name Size
emf-sdo-runtime-2.0.0.zip 3,139,406
GEF-runtime-3.0.zip 1,220,839
VE-runtime-1.0M2.zip 6,028,043
I do have a Eclipse log error for one of the VE pieces:
!MESSAGE Plug-in com.ibm.wtp.common.ui was unable to load class
com.ibm.wtp.common.ui.UITesterImpl.
!STACK 0
java.lang.ClassNotFoundException: com.ibm.wtp.common.ui.UITesterImpl
Which is probably why it isn't coming up. I looked at the util.jar in
D:\eclipse\plugins\com.ibm.wtp.common.util_1.0.0 and sure enough the
UITesterImpl class is missing.
Any suggestions?
Bud Curtis
Colorado Springs, CO
Re: Problem with VE on Eclipse 3.0 [message #58808 is a reply to message #58733] Tue, 07 September 2004 11:05 Go to previous messageGo to next message
Originally posted by: richkulp.NO.SPAM.us.ibm.com
M2 needs to be on Eclipse 3.0 Release version. Is that the versions of
Eclipse you have?
Also, start once with the -clean option to clear out cached information
from the Eclipse plugin cache. That way it will see you new changes.
Thanks, Rich Kulp
Re: Problem with VE on Eclipse 3.0 [message #58834 is a reply to message #58808] Tue, 07 September 2004 23:46 Go to previous message
I'm running: Version: 3.0.0, Build id: 200406251208 according to the Help
about box.
I tried the -clean option and it took a lot longer to come up, but I have
the same error in the log:
!ENTRY org.eclipse.core.runtime 4 1 Sep 05, 2004 10:19:26.640
!STACK 0
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader
..java:404)
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(Abstra
ctClassLoader.java:93)
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader
..java:307)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.jav
a:336)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBu
ndle.java:1313)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExte
nsion(ConfigurationElement.java:131)
nsion(ConfigurationElement.java:124)
nsion(ConfigurationElement.java:113)
com.ibm.wtp.common.UIContextDetermination$UITesterRegistryRe ader.readElement
(UIContextDetermination.java:153)
com.ibm.wtp.common.RegistryReader.internalReadElement(Regist ryReader.java:61
at com.ibm.wtp.common.RegistryReader.readRegistry(RegistryReade r.java:99)
com.ibm.wtp.common.UIContextDetermination.getCurrentContext( UIContextDetermi
nation.java:69)
com.ibm.etools.validate.internal.EventManager.isHeadless(Eve ntManager.java:4
31)
com.ibm.etools.validate.internal.EventManager.shutdown(Event Manager.java:323
com.ibm.etools.validate.plugin.ValidationPlugin.shutdown(Val idationPlugin.ja
va:137)
org.eclipse.core.internal.compatibility.PluginActivator.stop (PluginActivator
..java:74)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleConte
xtImpl.java:994)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s top(BundleContex
tImpl.java:990)
org.eclipse.osgi.framework.internal.core.BundleHost.stopWork er(BundleHost.ja
va:502)
org.eclipse.osgi.framework.internal.core.AbstractBundle.stop (AbstractBundle.
java:437)
org.eclipse.core.runtime.adaptor.BundleStopper.basicStopBund les(BundleStoppe
r.java:75)
org.eclipse.core.runtime.adaptor.BundleStopper.stopBundles(B undleStopper.jav
a:62)
org.eclipse.core.runtime.adaptor.EclipseAdaptor.frameworkSto pping(EclipseAda
ptor.java:551)
org.eclipse.osgi.framework.internal.core.Framework.shutdown( Framework.java:4
57)
org.eclipse.osgi.framework.internal.core.SystemBundle$1.run( SystemBundle.jav
a:182)
at java.lang.Thread.run(Unknown Source)
!SESSION Sep 07, 2004
21:40:35.00 ----------------------------------------------
eclipse.buildId=I200406251208
java.version=1.4.2_02
Bud Curtis
"Rich Kulp" <richkulp@NO.SPAM.us.ibm.com> wrote in message
news:chkiho$b30$2@eclipse.org...
> Eclipse you have?
> Thanks, Rich Kulp
Re: Problem with VE on Eclipse 3.0 [message #598169 is a reply to message #58733] Tue, 07 September 2004 11:05 Go to previous message
Eclipse you have?
Thanks, Rich Kulp
Re: Problem with VE on Eclipse 3.0 [message #598176 is a reply to message #58808] Tue, 07 September 2004 23:46 Go to previous message
about box.
!STACK 0
..java:404)
..java:307)
a:336)
ndle.java:1313)
nation.java:69)
31)
va:137)
..java:74)
xtImpl.java:994)
tImpl.java:990)
va:502)
java:437)
r.java:75)
a:62)
ptor.java:551)
57)
a:182)
Bud Curtis
> Eclipse you have?
> Thanks, Rich Kulp
Previous Topic:Problem with VE on Eclipse 3.0
Next Topic:HTML/JSP WYSIWYG editor
Current Time: Thu Nov 27 13:36:55 EST 2025
Powered by FUDForum. Page generated in 0.04157 seconds
