Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [teneo] Exception when using Enums
| [teneo] Exception when using Enums [message #58730] |
Mon, 23 October 2006 04:51  |
--------------090905090207090701020804
Hi Martin and everybody else reading this !
I have an enum MyEnum in my model and a class which has an attribute
with the type MyEnum. When I have a single object, set the attribute and
save everything in a HibernateResource, everything works fine.
But having two objects, where the attribute for both objects is set to
the same enmu-literal, I get an Exception.
This is the code which does not work:
Resource dbResource = domain.getResourceSet().getResource(uri, true);
TestClass element1 = TestmodelFactory.eINSTANCE.createTestClass();
element1.setEnumProperty(TestEnum.ITEM1_LITERAL);
dbResource.getContents().add(element1);
TestClass element2 = TestmodelFactory.eINSTANCE.createTestClass();
element2.setEnumProperty(TestEnum.ITEM1_LITERAL);
dbResource.getContents().add(element2);
dbResource.save(null);
I'll also attach a little screenshot describing the model and the
exception stack trace.
greetings,
Hans
name="exception.log"
Content-Disposition: inline;
filename="exception.log"
org.eclipse.emf.teneo.hibernate.HbStoreException: Exception when saving resource test
at org.eclipse.emf.teneo.hibernate.resource.HibernateResource.s aveResource(HibernateResource.java:214)
at org.eclipse.emf.teneo.resource.StoreResource.save(StoreResou rce.java:271)
at de.arcsolutions.remarc.platform.emftest.TwoResourcesLinkTest Case.testTwoResources(TwoResourcesLinkTestCase.java:77)
at junit.framework.TestCase.runTest(TestCase.java:154)
at junit.framework.TestCase.runBare(TestCase.java:127)
at junit.framework.TestResult$1.protect(TestResult.java:106)
at junit.framework.TestResult.runProtected(TestResult.java:124)
at junit.framework.TestResult.run(TestResult.java:109)
at junit.framework.TestCase.run(TestCase.java:118)
at junit.framework.TestSuite.runTest(TestSuite.java:208)
at junit.framework.TestSuite.run(TestSuite.java:203)
at org.eclipse.jdt.internal.junit.runner.junit3.JUnit3TestRefer ence.run(JUnit3TestReference.java:128)
at org.eclipse.jdt.internal.junit.runner.TestExecution.run(Test Execution.java:38)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:460)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:673)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(R emoteTestRunner.java:386)
at org.eclipse.pde.internal.junit.runtime.RemotePluginTestRunne r.main(RemotePluginTestRunner.java:58)
at org.eclipse.pde.internal.junit.runtime.CoreTestApplication.r un(CoreTestApplication.java:24)
at org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Caused by: org.hibernate.HibernateException: Illegal attempt to associate a collection with two open sessions
at org.hibernate.collection.AbstractPersistentCollection.setCur rentSession(AbstractPersistentCollection.java:410)
at org.hibernate.event.def.OnUpdateVisitor.processCollection(On UpdateVisitor.java:40)
at org.hibernate.event.def.AbstractVisitor.processValue(Abstrac tVisitor.java:101)
at org.hibernate.event.def.AbstractVisitor.processValue(Abstrac tVisitor.java:61)
at org.hibernate.event.def.AbstractVisitor.processEntityPropert yValues(AbstractVisitor.java:55)
at org.hibernate.event.def.AbstractVisitor.process(AbstractVisi tor.java:123)
at org.hibernate.event.def.DefaultSaveOrUpdateEventListener.per formUpdate(DefaultSaveOrUpdateEventListener.java:267)
at org.hibernate.event.def.DefaultSaveOrUpdateEventListener.ent ityIsDetached(DefaultSaveOrUpdateEventListener.java:216)
at org.hibernate.event.def.DefaultSaveOrUpdateEventListener.per formSaveOrUpdate(DefaultSaveOrUpdateEventListener.java:93)
at org.hibernate.event.def.DefaultSaveOrUpdateEventListener.onS aveOrUpdate(DefaultSaveOrUpdateEventListener.java:70)
at org.hibernate.impl.SessionImpl.fireSaveOrUpdate(SessionImpl. java:502)
at org.hibernate.impl.SessionImpl.saveOrUpdate(SessionImpl.java :494)
at org.hibernate.engine.CascadingAction$1.cascade(CascadingActi on.java:134)
at org.hibernate.engine.Cascade.cascadeToOne(Cascade.java:213)
at org.hibernate.engine.Cascade.cascadeAssociation(Cascade.java :157)
at org.hibernate.engine.Cascade.cascadeProperty(Cascade.java:10 8)
at org.hibernate.engine.Cascade.cascade(Cascade.java:248)
at org.hibernate.engine.Cascade.cascade(Cascade.java:223)
at org.hibernate.event.def.DefaultSaveOrUpdateEventListener.cas cadeOnUpdate(DefaultSaveOrUpdateEventListener.java:331)
at org.hibernate.event.def.DefaultSaveOrUpdateEventListener.per formUpdate(DefaultSaveOrUpdateEventListener.java:303)
at org.hibernate.event.def.AbstractFlushingEventListener.cascad eOnFlush(AbstractFlushingEventListener.java:130)
at org.hibernate.event.def.AbstractFlushingEventListener.prepar eEntityFlushes(AbstractFlushingEventListener.java:121)
at org.hibernate.event.def.AbstractFlushingEventListener.flushE verythingToExecutions(AbstractFlushingEventListener.java:65)
at org.hibernate.event.def.DefaultFlushEventListener.onFlush(De faultFlushEventListener.java:26)
at org.hibernate.impl.SessionImpl.flush(SessionImpl.java:985)
at org.eclipse.emf.teneo.hibernate.resource.HibernateResource.s aveResource(HibernateResource.java:210)
... 34 more
Content-Type: image/jpeg;
name="model.jpg"
filename="model.jpg"
/9j/4AAQSkZJRgABAQAAAQABAAD/2wBDAAYEBQYFBAYGBQYHBwYIChAKCgkJ ChQODwwQFxQY
GBcUFhYaHSUfGhsjHBYWICwgIyYnKSopGR8tMC0oMCUoKSj/2wBDAQcHBwoI ChMKChMoGhYa
KCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgo KCgoKCj/wAAR
CAB+AasDASIAAhEBAxEB/8QAHAABAQADAQEBAQAAAAAAAAAAAAYEBQcDCAIB /8QARRAAAQQB
AgIHBAcGBQMDBQAAAQACAwQFBhESEwcUIVRWk9MWFyIxFTdBdZaz1CMyNpXS 8CRCUWFzM3Gy
JTSBSFOGkcT/xAAYAQEBAQEBAAAAAAAAAAAAAAAAAQIDBP/EABwRAQEBAAMB AQEAAAAAAAAA
AAABEQISIQMxUf/aAAwDAQACEQMRAD8A+qUREBERAREQEREBERAREQEREBER AREQEREBERAR
EQEREBERAREQEREBERAREQEREBERAREQEREBERAREQEREBERAREQEREBERAR TfSXano9HGq7
dOaSC1XxNuWKWN3C6N7YXFrgR8iCAd14+weI75qT8R5H10FUilfYPEd81J+I 8j66eweI75qT
8R5H10FUilfYPEd81J+I8j66eweI75qT8R5H10FUihbWntJ07DoLefy8E7Nu KOXVd5rhuNxu
DY3+RWRR0jp2/EZaOVztmIO4S+HU994B+e24n+faP/2szlxtyVcv6skUr7B4 jvmpPxHkfXT2
DxHfNSfiPI+utIqkUr7B4jvmpPxHkfXT2DxHfNSfiPI+ugqkUr7B4jvmpPxH kfXT2DxHfNSf
iPI+ugqkUr7B4jvmpPxHkfXT2DxHfNSfiPI+ugqkUr7B4jvmpPxHkfXT2DxH fNSfiPI+ugqk
Ur7B4jvmpPxHkfXT2DxHfNSfiPI+ugqkXJNSPl0T0jaRgw9zKSVMlDcbbr3s lYuMk4HV+Ejn
PfwEcbu1u3z7dx2LraAiIgIiICIiAiIgIiICIiAii9VUxlte4DGWbWRhovxl +y+OlfnqF8jJ
abWFzontJ2Ej+wnb4lleweI75qT8R5H10FUilfYPEd81J+I8j66eweI75qT8 R5H10FUilfYP
Ed81J+I8j66eweI75qT8R5H10FUilfYPEd81J+I8j66eweI75qT8R5H10FUi lfYPEd81J+I8
j66eweI75qT8R5H10FUilfYPEd81J+I8j66eweI75qT8R5H10FUi5t0gaVpY bQWpMnjshqSK
9SxlmzBIdQ33hkjInOaeF0xB2IHYQQftVP0f5ezm9KUbl7hNlzA2R7RtxkD9 7b7N/wDbs/7f
JBRIiICIiAiIglelj6rNZfct38h6qlK9LH1Way+5bv5D1VICIiAiIgipMi2r n87G7LYymetM
PLtDdx/w8PaP2jez/wCPsK2WjLAsuzUjbMFkG8BzYBsx3+Hh+Xaf+3zX7lw+ UjyWQsY/JUoo
rcrZjHPSfK5pEbI/3hK3s+AH5faszA42xjxefdtRWZ7djnudFCYmt2jYwANL nH5M333+1eXh
8rPp2z+t3l45J0jaT04/py6NI34DEOjyb8tJeaaUZFp4rtcHSjh+MhxLt3b9 pJTVHSVncFqj
UWA0jp+KzW0yzHxxYypirFh9tkrQ57Wyw/s6oZGdmhzHb8J23/dHWsjp7F5H O4jM3avMyWJ5
3UpuY4crmtDJPhB2du0AfEDt9my1Wc6PtMZzK2Mhk8ZzrFnk9aY2xLHDb5Lu KLnxNcI5uE/L
ja7sAHyAC9TCEt9I2p4ekWbTl+LEYAT5B1TGNytScsvQ8vsnissfy3yB5YTA Ws342x8wPO4h
dGZfMa0odEWP1hf+lsbn7uXuXq0jC1tg1y58LJe3Z7WyAuDAGs24Glh4AT3X 3faY+nfpf6M/
xfXfpLl9Yl6v1rh4efyOLlc3b/Pw8W/xb79qe77TAwX0MzGcvGtu/SEMMdiV nVZ+LjD4HBwM
GztyBGWgcTth8R3DnXS1pXCaZk0M7T+Pix0d3W2LkmgrlzIONrZGhzYgeBhI A3LWji2G++wW
VnelTK43XtHH1YaOQw8mdgwdp8Fd/BWll4w1nWjJs+Zoa2R8bYeFnFwF/EA4 20fRtpVskcr8
bLPZZkIMp1mxcnmndYhbwxOdK95e4MBIDHEtG57O0pZ6NtK2cyMpJjZRZGQZ leCO5PHB1tu2
0/Ja8R8zsG7uHc9u++5QcvHS3rhs2TovwONj1NHDalh03ZhngslrHgRywTcT o7reESEtZynO
5buDcDt6B0Sa0sawhy4t28bPLRmZE6OCtNTs13Fg44rFaUu5bmvDmhzZHtds 4DYtO/rJ0SaH
ljkinwMU1YsnjjrTTyyQVhM7ik5ETnlkBJG+8YaR9hCoNOaXxGnJL0uLryiz ee2S1ZsWJbM8
xa0NbxSyuc8hoGwG+w3OwG5QbpERAREQci6X/rK0B/xX/wDyqrrq5F0v/WVo D/iv/wDlVXXU
BERAREQEREBERAREQEREErkvrT099y5P8+gqpSuS+tPT33Lk/wA+gqpBFZvV d6nrijhRFWo0
puD/ABdxrnCbdzf+nwkAbkiIcX+eRpdw/sWWudYfWGrshQBs56jDZtvoMtQU 5Y7FjFTTXa0T
ojGarW1yGyzN5c7pX7sGxPLkJ7BLqnCxWrVZ9+Pn138p0Ya4l8nDxGOMAftJ ANt2M3cNxuO0
b7HG36uToQXcfPHYqTtD45WHcOBWrxs9sTY5zR1ZdwusbOOz+Wlmw9F9qmLU 8DObbsGGhPBH
+zYA+Yiey1kcbQXtZ+65zSVM6R1Bq3UkWnn2dU2akV27Upv6pTrCQ8eEZckc XPje3tlG4AaN
g54JcCwM6B7ztNfSv0Zvm/pLk9Z6p9A3+dyuLh5nByd+Hi7OLbbfsVqsq4hp 7XWqM1nMHNNf
xFFttmOe3GOn4X24ZoIJJpY63IfNIGulmaJGzMY3k/GNo5C71l1JqdmgdHXL GoOG/maTbstn
lRVWueYoeCtE7kT8Ur+NzhEInPlcJCx0bWCI9qUrkOkDTlLK1sb1uzcu2aTc jDHjqFi7x1nO
LWygwseOEkfPf7R/qEHGsBqjLupW83TsRZPUNzIR5IYx1eKXlySacfPGI2Na JWhz2iIEO4nN
i4eIkyF9hHnsjkNQY3DYHWlnJYi1dhjObrNpzScZq3pJK4e2Hk/D1es7bg4w JTudnN261UsM
tVYbEQlbHMxsjRLG6N4BG44mOAc0/wCoIBHyIXqg5VW13mKsmNrf4bLTuu2q UldkZbbkbBas
QNeSCIw6RsXEOxo4oZTs2LmS1uqoiCV6WPqs1l9y3fyHrG6Iv4Go/wB/YFk9 LH1Way+5bv5D
1jdEX8DUf7+wILNERAREQEREEr0sfVZrL7lu/kPT2Xy/jvUnkY79KnSx9Vms vuW7+Q9VSCV9
l8v471J5GO/Sp7L5fx3qTyMd+lW4yeVFG1XrMp2bU07HyNbAWDZrC0Ekvc37 XtX4o5jrORZT
moW6kr4nzMMxjIcGloP7j3dvxt+a5368Zy676vW5rVey+X8d6k8jHfpU9l8v 471J5GO/SrE1
r0laf0dlYqGYm4ZTCLMx50MfJhLnND+GSRrpf3H/AAxNkf8AD+7u5od5W+kq hSq5C5exGXr4
6q+9DFbcIHMtS1BMZY42tlLwdq8xBe1jTwfMEgHojYey+X8d6k8jHfpU9l8v 471J5GO/SpqH
W9HCZ2LDyUclbvzcgRR1IWv43TNtOY3tcNv/AGkgLjs1vE0uIbxObKZPpTjs 43BT0Jq2nPpG
aB759QxMfHHUmrWZYZv2c4aON1csAdIHA77t7W7hV+y+X8d6k8jHfpU9l8v4 71J5GO/SrVYX
pIqyVpW5atZa6nSkyNq/Xrk1OqMksMbZadyeGQVuNrBxuLZWcJka1725VjpB r1LMNK9gs3Xy
880cMeO5cMszuZHO+N+8cjow1xrTN3Lhwlu7+BnxoMv2Xy/jvUnkY79Knsvl /HepPIx36VaT
MdMGmMQ6u2/JLDI5j5LMcssET6gZK+J/E18gMpbJDM0iASk8vsB4mcXtN0gz WM7hKeIwWSmp
2c1YxFq3NHHGwOhbY4+XxSNLtnQB/EGubwBzR+0HAA2vsvl/HepPIx36VPZf L+O9SeRjv0q9
cXrCplXY5mPpXp57VUWpYQIw+kOayIssAv8A2cgcZd29p/w8wG7mcJ8ukLIZ zFY6lawNrGw8
d2tTlbdpvn4ufYiha5pbLHw8PMLiDvxbAbt+aB7L5fx3qTyMd+lT2Xy/jvUn kY79KtfY6SMN
i9UVtM5S1FJlg+CrYmifDEwWJWt4GtgdKZyHF7Nixr2t4+1/wvLdfluk9xxz 58DgclbczJ1q
BceQWkPsRRyNd+2Bhl2laBHNy3h0jSWcLJCwKD2Xy/jvUnkY79Knsvl/HepP Ix36VSlHpCyE
U2av5Wb/ANLxk2T5lWtpy5xOiqvmaNrrpOQXERA/IAklnYflV09a15cvUxN/ F5LG5SzM2JtW
zyXOa18U8rJC6KR7eE9VmbsHFwLRu0AgkHsvl/HepPIx36VPZfL+O9SeRjv0 q1V3pSxsFqet
Ww+bu2IZmQObXhiDeJ12ak343yNYN5odgCQSHhwGzZOCvwOVgzWMZdrMljaX yQyRSgB8Usb3
RyRu2JBLXsc0lpLTtuCRsSHHekLF3Mb0laG67ncll+ZFd4eux128rZ1bfh5M Ufz3G/Fv8htt
279yXIul/wCsrQH/ABX/APyqrrqAiIgIiICIiAiIgIiICIiCVyX1p6e+5cn+ fQVUpXJfWnp7
7lyf59BVSDl2dwNGDOuZBh5XsqTdZoPb1otpzPAc6SINrPjG7tncJc9nE0Hh BLgb3TWOrYzD
V4qcBhEg50nG5znvkd2uc9zwHOcSe0uAP+oHyX6t4DD3LT7NvE4+ey/billr Mc92w2G5I3PY
AFsIYo4YmRQsbHExoaxjBsGgdgAH2BO30tva+Gcc8jln/wBU/wD+Gf8A9ygM fndSWulCzXnz
/U8lFrN1dlOfIWTNNjQwbRNx7I3RiIxfGLDuHtG5cP3l9KIg+S4shlsr9P6c t5fN6kv3MZmH
tsYu/YHMczfhhu46QcdVwe0NaIwxruNsW0jXP3ytE3cTU1touV2sfoCoej+u zr/XK7uKXrJ4
4eOy2RvY4PHAAC3l8I2DSF9VIg+e+kfJZGbWmWgx2qcu7G1ujybKwyU7vLZa mZI7lzkxAN3P
wu4o+HfYN/cLmnX53WWcr8jI5LLZKFmT6MnWa5iL2MmyR2c6SNjBtzWtcHFz R8DPiPC0bj6U
RB8wZDL5y71YHUWbhZD0WNzDmwXns5tpu5EriDvxcXCS4EOdw8JJaXNdVdEG WzDdf4DHXM1k
shVyWhqmXsNuzmXeyZQwPbv+7sx3CeHbi2Dn8T93HuqIJXpY+qzWX3Ld/Ies boi/gaj/AH9g
WT0sfVZrL7lu/kPWN0RfwNR/v7Ags0REBERAREQSvSx9VmsvuW7+Q9VS0HSF jrWX0DqXG4+P
m3bmMs14I+IN45HxOa0bnYDckdp7FFydMtWKR8cuj9XMkYS1zXQVgQR8wRz0 HQsphqeUlglt
CwJYWuax8FmWBwDuEuG7HDcHhb8/9F+MdgaOPudbg62+wI3RB09yafZri0kA PcQNy1vy/wBF
z730UvCOrPJreunvopeEdWeTW9dZ6zdxdWuZ0xHkcq6/Dk8ljpZoWVrYpSMZ 1qFjnuaxznNL
mbcyXZ0TmP8AjPxbhpbi3dCYe9iosbd6zPSZdu3XRmQN5jrbbLZWOLQDw7W5 NtiCNm9p2O8p
76KXhHVnk1vXT30UvCOrPJreutIpqGg6lfUUGdtZXL5DKRvikMtqWPZ5jisx N+BjGtaOG3J2
MDQS1rtuIvL2K6P8VjLuDtQWLzpMPVq1IA97CHMrw2YWF+zRuS23ITtt2hu2 2xBmffRS8I6s
8mt66e+il4R1Z5Nb10F3kNM47I2szLebLNHlsfHjLUJfwsdCwzHYEbOBPWHg nf7Bttt2zWV6
PpreRxV053JWL8F1s0+RmkjisNijr2mRMjEUbYzwy2S7ZzSHBzg/jbsxan30 UvCOrPJreunv
opeEdWeTW9dBTRaDqVnNdQyuXpSSsMd+SvLG198GWSV3McWExkyTzu3hMRHN OxHCzhyvY+o2
PGNgu3oHY/LT5iN7DGS6SZ05kjdxMI5ZFmRvYA4DbZ243Uf76KXhHVnk1vXT 30UvCOrPJreu
gsMDpx+PtZy3zIqk+RyAst6o1p5cLS3aLic3tEjhLK4ADZ1mXhJd+0dtc5io MzSjq2nysjjt
V7YMZAPHDMyZg7QewujAP+2/y+a5176KXhHVnk1vXT30UvCOrPJreugtX6Yj +nZsjXyeSqxW
ZmWbVKCRjYbMzGsY17ncPNHwxxAta9rHBmzmkOfxaq10fV7TLPPzubfK/q4r zOkhdJWbBO2e
JocYzzeF7Rs6fmuAL9iC95dP++il4R1Z5Nb1099FLwjqzya3roKCXQDZaGXx ztR5v6IyfXed
QAq8tvWjI6ThdyOYNnSuc3d52IG+47DsM1o+plMy/Ltu3qeUDIGQ2a5jJrmL rADmtexzSXNt
zNPEHDYggBwBUf76KXhHVnk1vXT30UvCOrPJreugoMb0b4fHxTRwWck5ss1a cmawJXcUF6W6
zd7gXO3kmcCXEktA7eLdxpcHioMNSkq1XyvjktWLZMhBPHNM+Z47AOwOkIH+ 23z+a5176KXh
HVnk1vXT30UvCOrPJreugx+l/wCsrQH/ABX/APyqrrq+ftRaq9s9faTtVcJl 8fBj22WSvvsi
aHGV0PDw8Ej/AP7bt99vsX0CgIiICIiAiIgIiICIiAiIghdWYTFZ7pJ03Vzm Mo5KszE5KRsV
yuyZjXiaiA4BwI32JG/+5Ww93Gh/Bum/5XB/SmS+tPT33Lk/z6CqkEr7uND+ DdN/yuD+lPdx
ofwbpv8AlcH9K9crmNRVspNBj9Lddpt4eC19IRx8e7QT8BG42O4/+FQVHyy1 IZLEPInexrpI
uIO4HEdrdx2HY9m6zOUtxc81Ne7jQ/g3Tf8AK4P6U93Gh/Bum/5XB/SuX6H1 jq1mmefFyspe
y2QpVqUDYny9VDsRFad/17TeYOFu2xlYeIvkJcXcC3cuvNXznk162Eoyw/R8 Vh1hpsubLYyM
1Jw4IpuEf9MSFvNcYy0xkvJ42aRa+7jQ/g3Tf8rg/pT3caH8G6b/AJXB/Sp+ LL5jJ5fRdya/
yK5zV3F2alVhZHZkgivsdK8kk8JdXY5se+zCTxGQhrm0uub+Rw3R5qfIwWYh kaePuWa80cOw
YWse6L4XFwJaA0EnscQTsAeEB5e7jQ/g3Tf8rg/pT3caH8G6b/lcH9K8tLwn Fa0zmFr2b0uO
hx9K5Gy5bltPbLLJaY8iSVzn7EQx/DvwjYkAFzia9BK+7jQ/g3Tf8rg/pT3c aH8G6b/lcH9K
qkQcw6TdA6Op9G2rLVPSen4LMGJtyRSxY2Fr43theQ5pDdwQQCCFvOiL+BqP 9/YFk9LH1Way
+5bv5D1jdEX8DUf7+wILNERAREQEREBeMlSvK8vkrxPefm5zASV7Igx+o1O6 weWE6jU7rB5Y
WQiDH6jU7rB5YTqNTusHlhZCIMfqNTusHlhOo1O6weWFkIgx+o1O6weWE6jU 7rB5YWQiDH6j
U7rB5YTqNTusHlhZCIMfqNTusHlhOo1O6weWFkIgx+o1O6weWE6jU7rB5YWQ iDH6jU7rB5YT
qNTusHlhZCIMfqNTusHlhOo1O6weWFkIgx+o1O6weWFkIiAiIgIiICIiAiIg IiICIiCVyX1p
6e+5cn+fQVUpXJfWnp77lyf59BVSAimsrrnTuJyk2OyGR5NyHh44+RI7bdoc O0NI+RH2qgqW
IrlSGzXdxwTMbJG7YjdpG4Ox7fkVmc+NuS+rlzWqOk9OGraqnAYg1rTIY7EX Uo+CZkQAia8c
OzgwABoP7uw22WVHhMVHHHHHjKLI42QRsa2uwBrIXcULQNuwRuJc0f5T2jZc 1070vxP05cy2
oaUtWuLVWtRe416vWjLSisf57DmRnZz37PkA4XMaC6Tdq2vvaw00EEmLxuXy hlZXf/g2QuY0
zWZKrWmV0gjJE0ZZ2PIduHML2Bzm6RdsxtFnJ4KVZvJmfZi2iaOCV/HxyN7O xzuZJu4dp43b
/Mr1rVoKsZjqwxQxue+QtjYGgve4ue7YfaXOLiftJJ+1RWc1TlfZ2XUGEFGO jTZIJaNuF8lq
1aZK6J1NhY8Njk5jOU145we9/wALSAOZYOtTChYsChZMsXM4KwdHzJeEkN4T x8Px7At4nDsc
OLhO4AeOEwmKwNV9XB4yjjaz3mR0VOuyFjnkAFxDQBvsAN/9gtgp/QuXvZzT 5uZWCtXutu3K
skVZ7nxt5NqWEbOcAXdkY7dhudzs3fYUCAiIglelj6rNZfct38h6xuiL+BqP 9/YFk9LH1Way
+5bv5D1jdEX8DUf7+wILNERAREQEREBERAREQEREBERAREQEREBERAREQERE BERAREQEREBE
RAREQEREBERAREQSuS+tPT33Lk/z6CqlBdIGTsab1PhNRHD5LJ4+CjcpTdQE bnxPlkquYXB7
2/CRC8bj5HYfaFp/fRS8I6s8mt66DqqLlXvopeEdWeTW9dPfRS8I6s8mt66D d4ro1oYmi2tj
svl4XQvrTVZt4HPqyw1BU5jN4i1xfC3hcHhze0loae1bA6IovkfLYvZKxYk6 iZZppmuc91W0
+0xx+HYcUkjgWgBobs1gYAFKe+il4R1Z5Nb1099FLwjqzya3roKCfQDTcq2K Oo83Q6tNbsxR
QirIxstmaSWSQCWB/wAX7VzA75hhIH7zy6wrRPhjLZJ5Z3F738cgaCA5xIb8 IA2aCGjs32A3
JO5PL/fRS8I6s8mt66e+il4R1Z5Nb10HRcHioMNSkq1XyvjktWLZMhBPHNM+ Z47AOwOkIH+2
3z+a2C5V76KXhHVnk1vXT30UvCOrPJreug6qi5V76KXhHVnk1vXT30UvCOrP Jreugq+lj6rN
Zfct38h6xuiL+BqP9/YFB636U4c9ozP4eppTU8dnIY+xUifLFXDGvkjc0FxE xO25G+wP/ZXv
RI0t0RTa4EOBIII2IOwQWSIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIi ICIiAiIgIiIC
IiAiIgIiICIiAiIg/jmhzS1wBaRsQRuCF4dRqd1g8sLIRBj9Rqd1g8sJ1Gp3 WDywshEGP1Gp
3WDywnUandYPLCyEQY/UandYPLCdRqd1g8sLIRBj9Rqd1g8sJ1Gp3WDywshE GP1Gp3WDywnU
andYPLCyEQY/UandYPLC9Yoo4WlsMbI2k77NaAN1+0QEREH/2Q==
--------------090905090207090701020804--
| Re: [teneo] Exception when using Enums [message #58830 is a reply to message #58730] |
Tue, 24 October 2006 01:48   |
Hi Hans,
I have a testcase which tests this and it works. This exception can occur when you try to save an
object in two different sessions. This occurs for example if you have references between objects in
different resources. If you save one resource then the refered object in the other resource is also
saved, when you then save the second resource this error occurs. Also the name of your testcase
seems to refer to this.
If this is the case then you can use a SessionController (url probably truncated by line break):
http://www.elver.org/hibernate/hibernateresources.html#Shari ng+one+Session+between+Resources%2C+One+transaction+when+sav ing+multiple+resources
to share a session between resources.
gr. Martin
> greetings,
> Hans
> ... 34 more
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
| Re: [teneo] Exception when using Enums [message #58906 is a reply to message #58830] |
Tue, 24 October 2006 03:40   |
Hi Martin,
I save everything in a single resource. The name of the test case is
just because I changed an old test case when trying to check out if I
can reproduce the Exception with a test case.
The funny thing is, that when I'm commenting out the marked lines down
below and run the test case twice, the second time it fails.
If you want to, I could provide you the project containing the testmodel
and the test case.
For now, here is my full testcode:
final String dataStoreName = "enumtest";
final HbDataStore dataStore =
HbHelper.INSTANCE.createRegisterDataStore(dataStoreName);
EPackage[] packages = new EPackage[] {TestmodelPackage.eINSTANCE};
dataStore.setEPackages(packages);
Properties properties = new Properties();
properties.setProperty("hibernate.connection.driver_class", "com.mysql.jdbc.Driver");
properties.setProperty("hibernate.connection.url","jdbc:mysql://127.0.0.1:3306/enumtest");
properties.setProperty("hibernate.connection.username","root ");
properties.setProperty("hibernate.connection.password","system ");
properties.setProperty("hibernate.dialect","org.hibernate.dialect.MySQLInnoDBDialect ");
dataStore.setHibernateProperties(properties);
dataStore.initialize();
EditingDomain domain = new AdapterFactoryEditingDomain(new
ComposedAdapterFactory(ComposedAdapterFactory.Descriptor.Reg istry.INSTANCE),new
BasicCommandStack());
String uriStr = "hibernate://?" + HibernateResource.DS_NAME_PARAM +
"=enumtest";
URI uri = URI.createURI(uriStr);
// Commenting the following lines out brings up an Exception when
// running the test case twice
reetings,
Hans
Martin Taal schrieb:
> Hi Hans,
> occur when you try to save an object in two different sessions. This
> occurs for example if you have references between objects in different
> resource is also saved, when you then save the second resource this
> error occurs. Also the name of your testcase seems to refer to this.
> gr. Martin
| Re: [teneo] Exception when using Enums [message #58957 is a reply to message #58906] |
Tue, 24 October 2006 05:41   |
Hi Hans,
Can you send me the test project and test case?
So if you don't comment out the lines then running twice does not result in an error?
gr. Martin
> Hi Martin,
> and the test case.
> "=enumtest";
> reetings,
> Hans
>> Hi Hans,
>> other resource is also saved, when you then save the second resource
>> this error occurs. Also the name of your testcase seems to refer to this.
>> gr. Martin
The Netherlands
| Re: [teneo] Exception when using Enums [message #59009 is a reply to message #58957] |
Tue, 24 October 2006 06:27   |
Hi Martin,
I'll send you the Project soon via mail. When not commenting out these
lines I can't even run the test case once without an exception.
greeting,
Hans
> Hi Hans,
> in an error?
> gr. Martin
>> Hi Martin,
>> testmodel and the test case.
>> "=enumtest";
>> reetings,
>> Hans
>>> Hi Hans,
>>> in the other resource is also saved, when you then save the second
>>> resource this error occurs. Also the name of your testcase seems to
>>> refer to this.
>>> gr. Martin
| Re: [teneo] Exception when using Enums [message #59309 is a reply to message #59009] |
Wed, 25 October 2006 14:55  |
Hi Hans,
I tested this and with me the error was that the enum property was set to unique, so I got a unique
constraint violation.
This was caused by a bug that the unique property of an EAttribute was still being used for enum and
lob. I have entered a bugzilla for this:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=162256
I have committed a fix, this will be in the next build (probably friday).
Can you check if setting the unique property of the EnumProperty to false helps? You need to
regenerate the sources for Teneo to see the new unique value as it reads the runtime model.
gr. Martin
> Hi Martin,
> greeting,
> Hans
>> Hi Hans,
>> result in an error?
>> gr. Martin
>>> Hi Martin,
>>> down below and run the test case twice, the second time it fails.
>>> "=enumtest";
>>> reetings,
>>> Hans
>>>> Hi Hans,
>>>> object in the other resource is also saved, when you then save the
>>>> gr. Martin
The Netherlands
| Re: [teneo] Exception when using Enums [message #594654 is a reply to message #58730] |
Hi Hans,
gr. Martin
> greetings,
> Hans
> ... 34 more
The Netherlands
| Re: [teneo] Exception when using Enums [message #594679 is a reply to message #58830] |
Hi Martin,
and the test case.
"=enumtest";
reetings,
Hans
> Hi Hans,
> gr. Martin
| Re: [teneo] Exception when using Enums [message #594695 is a reply to message #58906] |
Hi Hans,
gr. Martin
> Hi Martin,
> and the test case.
> "=enumtest";
> reetings,
> Hans
>> Hi Hans,
>> gr. Martin
The Netherlands
| Re: [teneo] Exception when using Enums [message #594709 is a reply to message #58957] |
Hi Martin,
greeting,
Hans
> Hi Hans,
> in an error?
> gr. Martin
>> Hi Martin,
>> "=enumtest";
>> reetings,
>> Hans
>>> Hi Hans,
>>> refer to this.
>>> gr. Martin
| Re: [teneo] Exception when using Enums [message #594831 is a reply to message #59009] |
Hi Hans,
gr. Martin
> Hi Martin,
> greeting,
> Hans
>> Hi Hans,
>> result in an error?
>> gr. Martin
>>> Hi Martin,
>>> "=enumtest";
>>> reetings,
>>> Hans
>>>> Hi Hans,
>>>> gr. Martin
The Netherlands
Current Time: Sat Nov 08 07:19:12 EST 2025
Powered by FUDForum. Page generated in 0.05663 seconds
